underdrive pulleys
Old Jul 29, 2005 | 03:49 AM
eZ's Avatar
eZ
Default underdrive pulleys
my mechanic said i dont need to go to underdrive pulleys but i need to replace them because he didnt install polished ones when i built the motor, what are the pros and cons...if i do go to an undrive system, if i go to a higher amp alternator will that help from slowing down the accessories?
Old Jul 29, 2005 | 05:39 AM
68COOP's Avatar
68COOP
Default RE: underdrive pulleys
The smaller the pulley, the harder the unit has to work. I would go with a 100 amp alt, but with the stock size wheel.
Old Jul 29, 2005 | 03:25 PM
69mach1377's Avatar
69mach1377
He needs to install new pulleys because they are not polished?
Can I be your mechanic?
I could use some more $$$
Old Jul 29, 2005 | 05:18 PM
eZ's Avatar
eZ
yea the whole motor is polished and then he put on some damn ugly *** rusted pulleys and the original alternator...doesnt fit the look of the rest of the motor...i think i can handle installing pulleys myself so he wont be making any $$$
Old Jul 30, 2005 | 03:40 PM
Scott H.'s Avatar
Scott H.
Default underdrive pulleys are great for drag cars
If you do daily driving, I would stick to the stock ratio pulleys. Less chance of overheat, uses stock size belt, and allows you to use a lower amp alternator that uses less HP at high rpm.
Just my two cents.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
