New with a question
Old Mar 21, 2010 | 08:18 PM
66289owner's Avatar
66289owner
Default New with a question
Hello,
I just recently aquired a 66 mustang hard top C code. While I was disassembling the engine, I noticed that in the valley under the valve covers was a 302 stamped. The intake manifold also has a 68 serial number. The stroke of the engine is 2 7/8" so it is not a 302, but I still need to check the crank for the 1m or the 2m to be sure.
Is it rare for a 66 to have a 302 cast 289?
Also How do I post pictures so that you all can take a look. She has some rust but is in fair condition compared to most. The interior has all original carpet, and headliner. the gauge cluster is in good condition as well as the dash.
Thanks for the input.
Old Mar 21, 2010 | 09:21 PM
JMD's Avatar
JMD
Your engine is not going to be original, Some 289s were built with "302" cast into the block but not until late 1967 models. So I have read anyway.
The easiest way to post is to post a link from Photobucket or a similar service.
The other way to post pics is to click the "Go Advanced" button visible when creating a post and then click "Manage Attachments", browse to your computer file and upload the PROPERLY SIZED file, kind of sucks this way, but it works.
Old Mar 21, 2010 | 10:03 PM
plainsman1876's Avatar
plainsman1876
Sounds like someone put a 302 n your car
Old Mar 21, 2010 | 11:18 PM
knuckless's Avatar
knuckless
my 68 has a 289 but like you said its stamped 302 in the valley and heads are stamped 289. they did this when they were fazing out the 289, used all the 289 internals on the new 302 blocks because the blocks were essentially the same
if you check behind the starter on the bottom of the block you can check the serial number of the engine itself to find out what year for sure it is.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
