toploader question
Old Mar 22, 2010 | 03:00 PM
lalojamesliz's Avatar
lalojamesliz
Default toploader question
i want to convert my 69 mustang from a c4 to a toploader with the soon to be 351w then a 408w im looking at the t5 trans but i read the toploader is way stronger (correct me if im wrong please) im leaning towards the toploader because i found one that has all new gaskets,fron and rear bearings and a new rear seal and it came out of 1969 fairlane with 390 engine. what is the max i should offer this guy? is this the big shaft toploader? please help
Old Mar 22, 2010 | 03:14 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The input shaft is shorter on a big block toploader than it is on a small block toploader which means the shaft will barely sit in the pilot bushing located in the crankshaft if you install it behind a small block. Not good.
Also the tailshaft length and shifter mounting points will be different.
Lots of info here.
TOPLOADER HISTORY
Old Mar 22, 2010 | 03:17 PM
71Mach14spd's Avatar
71Mach14spd
It depends on several things. What all are you getting with the transmission? If its "rebuilt" does he have receipts? Is it a close ratio or wide ratio? Things like these can make the price vary.
Old Mar 22, 2010 | 03:44 PM
2+2GT's Avatar
2+2GT
There is a special deep pilot bushing available to use the 390 trans on a smallblock without modification.
Old Mar 22, 2010 | 10:29 PM
lalojamesliz
cool do you know were i can find this special deep pilot bushing? i dont know if they have any receipts and its just the trans in the sale. its a wide ratio trans. it looks clean inside and out.. so what should i offer guys?
Old Mar 23, 2010 | 08:11 AM
6768 Fastback's Avatar
6768 Fastback
That shifter location can be a problem.. (Just say no to the recept saw)
Old Mar 23, 2010 | 09:23 AM
lalojamesliz
any other bad things guys?
Old Mar 23, 2010 | 09:49 AM
MBDiagMan's Avatar
MBDiagMan
Yes, the toploader is indeed stronger than a T5.
The toploader you describe does not sound like it is rebuilt. Putting gaskets and seals in it is akin to a coat of paint. That said, rebuilding one is not normally a big deal. Constant mesh transmissions typically only need fresh brass and replacement of bearings that don't pass inspection.
Old Mar 23, 2010 | 11:01 AM
2+2GT's Avatar
2+2GT
Yeah. The 390 toploader is no stronger than the 289 toploader.
Old Mar 23, 2010 | 11:45 AM
MBDiagMan's Avatar
MBDiagMan
Yes, a top loader is a top loader EXCEPT for gearsets. Any toploader is pretty darn stout. It could also be said that a 289 toploader is as strong as an FE toploader.
The FE version will have a taller gearset than the one for a 289. This actually should work well with the motors you list. Both of these engines will be able to provide more get it rolling torque than a short stroke engine so the tighter ratio gearset should work good for you.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
