Flywheel Removal
Old Jul 31, 2005 | 12:22 AM
stangboy690's Avatar
stangboy690
Default Flywheel Removal
I have my motor out and it is hanging from an engine puller, Want to get it on the stand soon but cant get the flywheel off...Really would appreciate any help or advice...its a 69 coupe 302 by the way..didnt know if that would change anything
Old Jul 31, 2005 | 12:29 AM
dodgestang's Avatar
dodgestang
Default RE: Flywheel Removal
Since the motor is out and you have nothing to break the nuts against you need to use an impact. The only other option is to have a friend hold the crank from spinning with a big **** socket anc breaker bar, but most of the time you end up breaking the front bolt loose before you have the flywheel off.
Old Jul 31, 2005 | 02:28 PM
overdrive's Avatar
overdrive
You can hold the flywheel with a large screwdriver or tire tool held between a ring gear tooth and a trans/bellhousing alignment pin.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
junior04
Sep 28, 2015 10:53 AM
