Tach Installation OEM Ford? Help!
Old Apr 7, 2010 | 09:48 PM
dchappy's Avatar
dchappy
Post Tach Installation OEM Ford? Help!
Has anyone installed an OEM Tach in a 68 ? I bought this 68 GT, but previous owner restored it using std dash cluster and std wire harnesses. I'm installing the GT dash cluster with Tach. I'm not going to spend mucho dollars converting back to the GT wire harness. I want to wire the Tach independent to the harness. I have figured out the wiring for the Alt-Oil lights, but the Tach has me stumped. Haven't found any factory wire diagrams that will help. I'm useing a Mallory electonic distributer and Mallary Coil. Will apprecite any help on this.
Don
Old Apr 8, 2010 | 06:31 AM
kalli's Avatar
kalli
hiya
the original tach is wired inline (totally different from the normal paralel setup at coil-). it goes like a cable extension between ignition switch and coil+
you know when you have key in ingition position it will feed 12V+ to the coil+. right behind the ignition switch (maybe 2inch) is a quick disconnect which at stock leads to the pink resistor wire. disconnect and place the tach inbetween
the bad news is: it might not work with your type of ignition (mallory). it only works if there's voltage going up and down at coil+ as the coil pulls it.
Well anyway givbe it a try at least ...
Old Apr 8, 2010 | 06:34 AM
kalli's Avatar
kalli
before
ignition switch ---[-----------------]firewall[------ coil+
after
ignition wsitch ----[----tach ---[-------------------]firewall .....
Old Apr 8, 2010 | 02:11 PM
dchappy's Avatar
dchappy
Thanks, I'll give that a try
Don
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
NTO_GUY
Dec 24, 2015 11:23 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
