Quick Horsepower
Old Apr 11, 2010 | 08:56 PM
stang_boy2011's Avatar
stang_boy2011
Default Quick Horsepower
What can I do for quick horsepower on a 1973 351 Cleveland? Also what aftermarket heads will fit on it?
Old Apr 11, 2010 | 09:31 PM
71Mach14spd's Avatar
71Mach14spd
The normal stuff: headers, bigger carb, new cam, HEI, new heads, aluminum intake etc.
Old Apr 11, 2010 | 09:32 PM
longlive289s's Avatar
longlive289s
nitrous lol. it is the quickest hp per $
just check out summit racing, cj pony parts, etc
not sure exactly what your looking for
71Mach14spd
Oh and as for the heads it depends on your compression.
Old Apr 11, 2010 | 10:10 PM
67mustang302's Avatar
67mustang302
Yes, nitrous.
Old Apr 11, 2010 | 10:37 PM
racin66coupe's Avatar
racin66coupe
whats your budget?
Old Apr 12, 2010 | 09:12 AM
rtintwo's Avatar
rtintwo
First you should spend some time reading up on the cleveland. Heads and nitros would be some of the last things i would do if my goal was quick, easy horsepower. With 4 barrel heads it is rediculously easy to get over 400 horsepower. Long headers, cam and a 700CFM carb and you are there. On 2 barrel heads you are still close to that in power.
The only reason to spend the cash on new heads is if you are building a drag car and want to save the wieght. The thing to keep in mind you havent had the oil restictor install then limit your time above 6K RPM.
Old Apr 12, 2010 | 10:03 AM
MBDiagMan's Avatar
MBDiagMan
If you are looking for meaningful information, you really need to be more specific as to your goals. General questions will get responses that are all over the map and probably won't be very useful to you.
Horsepower wins races, torque makes a car more fun to drive. Are you looking to win races? How much money do you want to spend? Are you aware that there is no such thing as quick horsepower? Engine modification takes money and time. There are no shortcuts.
There is a wealth of information on this forum. Explain what you are trying to accomplish and I'm sure that good information will then come your way.
Old Apr 12, 2010 | 06:22 PM
stang_boy2011
Ive heard that horsepower is nothing without torque though?
Also, I'm thinking stuff like ignition, Headers, exhaust, heads. I'm trying to accomplish better fuel economy by getting a better spark to burn the fuel more efficiently. So I also want to try to get her to breathe better which should also help with fuel right? I'm aware that my car isn't going to be the most fuel efficient out there. But I want to make it as good as I can while keeping the power.
Old Apr 12, 2010 | 06:45 PM
71Mach14spd
As previously stated i would not change the heads. My 351c has the stock cast iron 4v heads and im making just shy of 500 to the flywheel so heads are a waste of 1500+ dollars IMHO.
