Collapsed upper radiator hose???
Old Apr 20, 2010 | 01:46 PM
  #21
ic237's Avatar
ic237
Originally Posted by scootchu
Wow, I don't know. I haven't looked at what my cooling system looked like when it was closed (clear tube), but that seems like a lot of air in there.
The engine sounds good otherwise. Did you ever burp the system and release all of the air?
Yeah, I actually flushed it 3 times. I drove it 25 miles and I still get the mystery bubbles. I always though those bubbles were from the pump like the prop on a boat. I don't have the classical white smoke or the smell of coolant burning. The oil level hasn't dropped. It runs pretty good I guess. I guess I need to have someone do a leak down test. The pressure was a lot more tame than the first time I did it. It seems to only jump a quater pound when I rev it. Crap! I emailed the engine company and I guess its going to be a battle since the won't respond to my emails.
Old Apr 20, 2010 | 02:19 PM
  #22
stangtjk's Avatar
stangtjk
I had issues with my cooling system as well after replacing the original 289 with a remanufactured one. I actually went through 2 reman units, couldn't get either one to cool properly. I replaced the radiator, t-stat, pump, hoses, and added a fan shroud but nothing worked. I never had any problems before the reman engine was put in. I finally got fed up and dropped in a mod motor. Hopefully you'll have better luck.
Old Apr 20, 2010 | 03:29 PM
  #23
scootchu's Avatar
scootchu
You should elevate the front end of the car and start it cold with the cap off and the air pockets should find their way out. I would think that cavitation is possible, but that looks like a lot of big bubbles in there. Like I said I have never looked at mine like you have yours set up, so it may be normal.
Old Apr 20, 2010 | 03:57 PM
  #24
ic237's Avatar
ic237
I forgot to mention, i did add a bottle of napa kool. Its cavitation mojo for diesel engines. I think thats why the pressures werent so crazy like before.
If you think I got bubbles now, you should have seen it before. The mystery bubble are a constant except at idle its only one or two here and there. They never go away even at idle. The have been there since day one.
I understand its an unusual setup and a little hard to relate.
Granatelli Sales
Jan 20, 2020 12:34 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
