heater core
Old Apr 28, 2010 | 08:39 PM
texas67coupe's Avatar
texas67coupe
Default heater core
So just moved from TX to KY and went to pull the cover off the car when I noticed a small puddle under the passenger side. It was def anti freeze. so was curious when the drip was from under the passenger seat. So then open the door and feel a completely soaked carpet and the heater core cover dripping green. So I check the hoses first (no leak) then I pulled the clips and see that it is definitely leaking from the core. I bypassed the heater core, and now I ask do i really need to mess with replacing this, or should I just let it be and go with no heat?????? It's a weekend cruiser at best. I take it out for a 20-30 min ride then put her back away about 2 times a month. Does it hurt anything to not replace this right away or will things be fine with the hoses bypassed? thanks.
Old Apr 28, 2010 | 08:50 PM
kbryan's Avatar
kbryan
"Things" will be fine....... if you don't need heat or defogging it's no big deal.
Old Apr 28, 2010 | 10:01 PM
Bitter's Avatar
Bitter
A new heater core is less than $40 and pretty easy to install.
Old Apr 28, 2010 | 10:12 PM
Houndstooth's Avatar
Houndstooth
Old Apr 28, 2010 | 11:13 PM
71Mach14spd's Avatar
71Mach14spd
This is true but if you don't have the time and don't feel like spending the money right now just leave it. I drove my truck with it like that for almost a year before i finally got around to changing mine,
Old Apr 29, 2010 | 04:14 PM
texas67coupe
thanks everyone. I will replace it when I do my interior. I am sure it will be easier to do with no dash pad or glove box in. I just wanted to make sure there wasn't any immediate issues other than having no heat.
Old Apr 29, 2010 | 04:30 PM
rtintwo's Avatar
rtintwo
Like others have said it wont hurt anything. But sense your carpet got soaked you should pull the carpet up and make sure it gets a chance to dry out. Leaving the coolant soaked carpet on the floor pans will cause more rust issues.
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
