Competition Engineering Shocks
Old May 3, 2010 | 03:48 PM
urban_cowboy's Avatar
urban_cowboy
Default Competition Engineering Shocks
I am looking at putting a set of adjustable shocks on the front and rear of my '69. I like the idea of having adjustable shocks that I can change the setting on depending on if I am street driving or strip driving.
The Competition Engineering shocks are pretty inexpensive $45/each. The fronts are adjustable between 90/10, 80/20, or 60/40 while the rears are adjustable between 70/30, 60/40, or 50/50. I think I can dial in a 90/10 and 50/50 for drag racing then switch to 60/40 and 60/40 for street use and street racing.
I am not sure about the quality, but like the idea. Any opinions or experience with these? If so, what application did you use them in?
Old May 3, 2010 | 04:15 PM
urban_cowboy
My other option is to put on a set of Koni Classic 82 Series. They are also adjustable, but would require them to be removed from the car before adjustment which kinda stinks.
Old May 3, 2010 | 04:24 PM
kalli's Avatar
kalli
i have the konis in the front and will get the same (to ditch my KYBs) for the back. they are great for setting up. i actually never changed the front setting as i'm quite happy with it. mayeb a bit stiffer would be an idea as the rear now stiffened up as well ... but yes, you can't do it in-car, or at least i wouldn't know how. love the konis, but if you want to change frequently, probably not the best idea ?
Old May 3, 2010 | 04:29 PM
67mustang302's Avatar
67mustang302
Honestly, if you're going to get adjustable shocks then just spend the dough and get the 2 way TCP adjustables. They can be adjusted on car and are 2 way with 256 adjustment combination. Getting a 1 way adjustable shock is a slight improvement over a non adjustable, but not worth the money imo. Bump and rebound have to both work together to be effective, and a 1 way doesn't give you individual control over each one, so if there's not a setting close to what you need then the adjustables won't help too much.
Of course, the TCP shocks are expensive.
Old May 3, 2010 | 05:06 PM
urban_cowboy
Thanks...I forgot about the TCP shocks...that is a good idea. I will look into that. I gather that the CE shocks are dual adjustable based on pre-sets, but they are pretty cheap compared to higher-end shocks, so I am little skeptical.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
Luke9222
Sep 4, 2015 06:46 AM
