68 mustang rearend
Old May 12, 2010 | 09:07 PM
matto1975's Avatar
matto1975
Default 68 mustang rearend
I found the thread about converting from an I6 to a V8 but I didn't see my question answered. The car I bought was an I6 and I am putting a 302 in it. I already did a complete suspension change to handle a small block V8. I know it was mentioned that a 68 is easier to convert but will my rear axle hold up? I was planning on changing the rearend gears to 3.73s but should I change the whole thing? What size axle comes in the 68 I6? I have tried to google it but all the websites that mention specs on this car were about engines. I have no idea if a V8 was ever put in it because the entire engine bay was empty when I bought it, except for a master cylinder and steering box. Thanks in advance
Old May 12, 2010 | 09:28 PM
rtintwo's Avatar
rtintwo
To tell if the car had a 6 in it look at the VIN and if the fifth digit is a T then it was a 6, anything else was an 8. To tell about your rear axle, four lugs is an 8", 5 lugs is a 9". It is possible to change the axles and build a 8" to take up to 300 horsepower but its very easy to find a 9" and spend about the same amount and have a stronger differential.
Old May 12, 2010 | 10:50 PM
andrewmp6's Avatar
andrewmp6
No 4 lug is a 7.5 5 lug is 8 inch and 9 inch.And yes if its a 7.5 you need to change it out to a 8 inch at least.
Old May 13, 2010 | 04:44 AM
tx65coupe's Avatar
tx65coupe
You need at least an 8 inch rear end. It will be fine for most V8 applications. Like andrew said though 4 lug is 7.5, 5 lug is 8 or 9 inch.
Old May 13, 2010 | 11:38 AM
matto1975's Avatar
matto1975
thanks guys, that helps a ton
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
