Sludge
Old May 20, 2010 | 09:25 AM
nassaubayman's Avatar
nassaubayman
Default Sludge
What's the cause of this sludge deposit?
Old May 20, 2010 | 11:01 AM
kalli's Avatar
kalli
ups. can you pull all sparkers and post picture of each?
Old May 20, 2010 | 11:54 AM
rtintwo's Avatar
rtintwo
Looks to like the plug didnt seal up at some point in time. Had some AF mixture and exaust leak out and deposit.
Old May 20, 2010 | 11:57 AM
stephen.osborne1's Avatar
stephen.osborne1
Can't say for sure without more info, but looks like you have oil leaking into the cylinder and out the spark plug hole... bad rings or valve seal(s). Does your car burn a lot of oil? Blow blue smoke? Do you have more pics of surrounding area? Could be as simple as a valve cover leaking above, but can't tell from your picture.
Old May 20, 2010 | 12:03 PM
nassaubayman
I'll have to take spark plug pictures tonight. As I recall, I think they all looked nice and dry. A couple of the plugs may have had some oil on the threads, but not down where they fire.
Here's pics of the engine on the stand with the plugs still in. Look at #4 & #7. The build-up doesn't look like it came down from the valve covers.
Old May 20, 2010 | 01:31 PM
FoMoJoe's Avatar
FoMoJoe
Blown piston ring?
Old May 20, 2010 | 01:47 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Sounds right to me.
Old May 20, 2010 | 02:35 PM
kalli's Avatar
kalli
As before. Plug picture needed. Could be just that it wasn't tight
Old May 21, 2010 | 08:30 AM
nassaubayman
Here are the plugs. 1-4 are the passenger side, front to back. 5-8 are the drivers side. All 8 plugs are dry where it matters most. 4 and 7 are oily around the threads.
Attached Thumbnails Sludge-plug-1.jpg   Sludge-plug-2.jpg   Sludge-plug-3.jpg   Sludge-plug-4.jpg
Old May 21, 2010 | 08:32 AM
nassaubayman
I couldn't put all the pictures into one post. Here's plugs 5-8.
Attached Thumbnails Sludge-plug-5.jpg   Sludge-plug-6.jpg   Sludge-plug-7.jpg   Sludge-plug-8.jpg   Sludge-plugs.jpg
