Who makes a booster set-up for 66?
Holy triple post Batman!
MPB = Master Power Brakes
You can also look on eBay. Those run just under 300. Also give www.mustangsteve.com a try. He sells plans for a DIY set-up that uses auto parts store parts which as we all know come with warranty.
You could try giving them a call
http://www.abspowerbrake.com
They sell a booster with the factory master cylinder but there are other options
I did not see the booster and master cylinder for sale on their website. What is with the electric master cylinder. I see a vacuum pump, that has to be pretty noisy with the pump running under the dash. I know my neighbor has a pump for this air ride and that thing drive me crazy when I ride with him.
Does anybody know if the booster and master cylinder set up fits the 66 with stock shock towers?
Thank you for your answer.
So you're not interested in the excellent 64-66 booster/master I posted?
If you are running the SSBC setup, have realized it is quality product, then you might inquire about using a SSBC Booster/Master.
Yes, SSBC does make a setup for the Automatic transmission 65 66. If a 4/5 speed, it will not fit.
Mustang Steve Cable clutch setup is the Cats Meow with the better, Straight push, non several pivot setup bracket as the old old original one. More moving parts, more fail.
Dan @
Chockostang
That pictured one is to fit standard like already stated. Scott Drake and them all sell the same one. Unlike the picture, it comes chromed now. Be prepared to take it apart and clean out the chrome chips though.
Here is one sold by Chockostang who is very reputable on these forums. Under 300.
http://cgi.ebay.com/ebaymotors/65-66...#ht_1207wt_721
