302/351
Old May 23, 2010 | 12:38 PM
stangcoupe1970's Avatar
stangcoupe1970
Default 302/351
I'm going to the junkyard tomorrow to pull a motor to build for my 70 coupe, I want a 351w.
so I'm wondering what the differences between the 2 are.
also what other cars had the 351w with carburetor?
Old May 23, 2010 | 03:46 PM
JMD's Avatar
JMD
All kinds of 70s and early 80s mid size cars and trucks had 351W's.
A 351 has an inch taller deck than a 302, this makes a 351 both taller and wider than a 302. Not an issue for your 70.
351s and 302 share lots of parts, and a few key parts are not shared like crankshaft, rods, intake manifolds, distributors, a few assorted brackets etc. Essentially a 351 is a bigger 302.
All in all we went with a 351 in the 66 because we kind of fell into the engine for a good price, although you will likely find that the junkyard will have lots more 302s.
Old May 23, 2010 | 11:01 PM
vonkysmeed's Avatar
vonkysmeed
Learn parts interchanges quickly and how to visually identify a 302 vs a 351 and the difference between the 351 w and Cleveland.
As for the windsor vs Cleveland, I use the valve covers to quickly identify. All windsors have 6 bolts, clevelands have 8.
Happy Hunting.
I found my 351 by mistake in an 82 mustang gt that someone took the 302HO out and dropped in a used up 351.
after the rebuild, glad I kept it.
Old May 24, 2010 | 01:36 AM
stephen.osborne1's Avatar
stephen.osborne1
Happy Hunting.
Also, don't confuse the 351M/400. It has Cleveland style heads so it could be confused with a real Cleveland...
I'd find a truck block 351 with a roller cam if I were going to do a junkyard motor build up... There are tons out there in EFI form, which are easily converted back to Carb.
Old May 24, 2010 | 10:31 AM
vonkysmeed's Avatar
vonkysmeed
very true. I have always looked for the windsor and did not learn the differences between the cleveland and the M block.
Old May 24, 2010 | 08:03 PM
stangcoupe1970
I pulled a 302 out of a f100 "explorer" ironicly my daily is an explorer
it looks really good and the bottom end is useable so i'm going to leave it alone
mtflyboy25
Jan 26, 2014 05:14 PM
mtflyboy25
Dec 7, 2013 08:55 PM
RVC
Nov 24, 2008 08:38 AM
jstanley
Jul 4, 2008 03:23 PM
SHOPGUY
Aug 23, 2007 09:32 PM
