Hyper Lube Super Coolant
Old May 26, 2010 | 07:37 PM
hotrod351's Avatar
hotrod351
Default Hyper Lube Super Coolant
any one use this product. checker has it on sale, buy one get one free.
Old May 29, 2010 | 08:43 AM
hotrod351's Avatar
hotrod351
for what its worth this product works. lowered my 70 mustang temp 10 degrees, thats with the ac on and 100 degrees outside, cruising and at idle.
Old May 29, 2010 | 12:15 PM
4reboy's Avatar
4reboy
is this basically just like water wetter?
Old May 29, 2010 | 02:32 PM
hotrod351's Avatar
hotrod351
agree. it works.
Old May 29, 2010 | 03:59 PM
Starfury's Avatar
Starfury
Yes, essentially water wetter. It's not a fix in a bottle, but it does work for its intended use, which is to increase the performance of the cooling system by decreasing the surface tension of the coolant.
Old May 29, 2010 | 07:12 PM
nba1341's Avatar
nba1341
Ive used it and I liked the results. I didn't do any specific measurements though so can't tell you if the temp really did lower 10 degrees
Old May 29, 2010 | 08:15 PM
hotrod351's Avatar
hotrod351
i have a vdo temp gauge mounted under the dash, also have the dash one connected. wife said the temp dropped 10 degrees right after i put it in. im here in arizona where temps get to 125 degrees so any little help is worth it.
Old May 29, 2010 | 09:59 PM
nba1341's Avatar
nba1341
+1 I used it last summer here in California and it really did help for my city driving which my car sometimes likes to get so hot it wants to die at idle.
Old May 29, 2010 | 10:06 PM
hotrod351's Avatar
hotrod351
ok then you know what i mean. even 10 degrees is good. and its cheaper. figure, well now, 2 for $10.00, so one plus a little antifreeze and the rest distilled water. i did the 15% antifreeze. so it cost me about $10.00 instead of the $20.00 it would cost with antifreeze mix and it runs cooler.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
wraith777
Sep 28, 2015 10:49 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
MusicCity615
Sep 12, 2015 07:05 AM
