Disk brake grabs
Old May 27, 2010 | 08:44 AM
elkbowhntr's Avatar
elkbowhntr
Default Disk brake grabs
Hello,
We did a front drum to disk conversion using the 1980 Granada about 3 years ago. We notice that the driver side spins freely when the car is jacked up, but the passenger side is pretty tight. We replaced the calipers with new, with no change.
Is this normal, or could there be an issue with the distribution block? Any other suggestions?
Thanks for the input.
Tim
Old May 27, 2010 | 09:22 AM
photocliff's Avatar
photocliff
Are both sliders properly lubed? If not then they won't release properly and drag more on the rotor. Also if the caliper cage is damaged it would cause it to sit and drag too.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
