Engine & Engine Bay Clean Up
Old May 30, 2010 | 07:35 PM
nassaubayman's Avatar
nassaubayman
Originally Posted by tx65coupe
That looks nice. I hope your project goes smoothly.
Smooth..... Hah!
Got sick and lost at least a week.
Found a broken oil pan in the block. Had to take it to a machine shop. Lost a week.
Fretting a little over how the AOD conversion will go. I bought the conversion kit, so I'm hoping that will be smooth.
End the end, its all fun though.
Old May 30, 2010 | 09:37 PM
JMD's Avatar
JMD
Originally Posted by nassaubayman
Smooth..... Hah!
I have to say it, I am sure you know already, but make sure the TV cable is set right or things won't go smoothly at all....
Old May 31, 2010 | 09:19 PM
nassaubayman
I took the transmission to a shop to have it rebuilt. When I picked it up, I told them I was going to get the car running, but not put it in gear. I told them I'd roll it onto a trailer and take it to them to have them adjust the TV cable properly.
After doing my research, I'm relatively confident I could to it myself. But I think I'll take it to them just so they won't be able to renege on the warranty.
Old Jun 2, 2010 | 12:01 PM
nassaubayman
Originally Posted by LynnBob Mustang
Looking good!!
Did you use rattle can paint to paint the engine bay or a spray gun?
Lynn
I brushed POR 15 on the floor pans, frame, and cross member. I used a rattle can on the firewall and inner fenders.
[QUOTE=What did you use for the engine paint? [/QUOTE]
I used rattle cans of hi-temp engine enamel. Old Ford Blue on the block and Silver on the intake manifold, bought at the local AutoZone.
Old Aug 3, 2010 | 06:21 PM
nassaubayman
Almost done. Lots of "that didn't go as expected" moments with this AOD conversion. But the car is on the road again.
I still need to put the hood back on.
I haven't decided on plug wires. I can't decide between keeping blue ones, changing to yellow Accel wires (old school hot rod style), or black wires to complement the black valve covers. I can't keep it as it is with one yellow and 8 blue wires, that's for sure!
Old Aug 3, 2010 | 06:33 PM
nba1341's Avatar
nba1341
Black wires look good with black valve covers I recently switched over to black wires after having 5 yellow and 3 purple
Old Aug 4, 2010 | 06:22 AM
tx65coupe's Avatar
tx65coupe
Thats cool that its back together now. My vote goes for black or blue plug wires. I'm runnin blue ones right now, but may switch to black ones at some point. I'm not big on the yellow ones.
Old Aug 4, 2010 | 02:40 PM
SJs 66coupe's Avatar
SJs 66coupe
I like the valve covers. Been thinking about getting some of those.
My current ones are chrome and a real pita to keep clean. They've got a haze from something on them and I can't get them clean.
Car looks great!
The blue wires look good. Only other color I'd consider would be black.
By the way, where did you pick up your radiator hoses from?
Old Aug 4, 2010 | 03:10 PM
nassaubayman
Car looks great!
The machined fins on the valve covers are going to be just as much PITA as my old aluminum ones, but not near as much work.
I bought the steel-braided hose cover kit from AutoZone. I covered my existing hoses.
Where in Houston are you? I'm the Clear Lake area, close to NASA.
tx65coupe, where are you located?
Old Aug 4, 2010 | 03:47 PM
SJs 66coupe
I'm north in The Woodlands / Spring area
