Engine & Engine Bay Clean Up
Old May 29, 2010 | 08:23 PM
nassaubayman's Avatar
nassaubayman
Default Engine & Engine Bay Clean Up
I pulled the motor and transmission to convert to an AOD and to pretty everything up. I'm about done with the motor. Tomorrow I start working on the engine bay. Last weekend, I sprayed it with Easy Off oven cleaner, then used my pressure washer on it. It blew the paint off the frame. That's a good thing though, since I was planning of painting it with POR 15.
Old May 29, 2010 | 09:29 PM
FoMoJoe's Avatar
FoMoJoe
Looks great! I had a problem with those valve covers where the pcv and oil breather grommets would never hold on tight enough. I called ford motorparts and they sent me a free cover that they thought might be in spec. I ended up gluing once side down, the other side is better for the oil breather, but still needs to be improved.
Old May 29, 2010 | 09:35 PM
nassaubayman
Not something I was wanting to hear
Old May 29, 2010 | 10:03 PM
nba1341's Avatar
nba1341
Love it! A freshly painted engine is a nice sight.
Old May 29, 2010 | 10:12 PM
nassaubayman
It's actually the "Old Ford" (dark) blue. The flash on the camera made it look light blue. I'll retake the pictures tomorrow.
Old May 30, 2010 | 06:13 PM
nassaubayman
Engine Bay before and after
Old May 30, 2010 | 06:49 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Looking good!!
Did you use rattle can paint to paint the engine bay or a spray gun?
Lynn
Old May 30, 2010 | 07:11 PM
tx65coupe's Avatar
tx65coupe
That looks nice. I hope your project goes smoothly.
Old May 30, 2010 | 07:13 PM
Bitter's Avatar
Bitter
POR15 is a bit thick to spray so I assume he brushed it. Eastwood Chassis Black does a nice job as well.
Old May 30, 2010 | 07:34 PM
nba1341's Avatar
nba1341
What did you use for the engine paint?
