Brake Distributor Block
Old Jun 10, 2010 | 06:13 PM
wonso79's Avatar
wonso79
Default Brake Distributor Block
Does anyone know where I can get a Brake Distributor Block for my 1965 mustang with drum brakes?
Old Jun 10, 2010 | 08:49 PM
rtintwo's Avatar
rtintwo
What is the problem with the one in your car now, or maybe not in your car?
If the body is still good on your block then its pretty simple to unscrew the end and change the seals out and put a new copper washer on it. Any good parts store will have the seals and washer. This will probably save you about $100 bucks.
As far as i know nobody makes a block exactly like the original. You have to buy a disk brake block and mod your lines to fit. But if somebody out there knows of one like the original being make please do correct me.
Old Jun 11, 2010 | 04:36 PM
chockostang's Avatar
chockostang
Yes, your block will work fine--Of course unless if not present.
Adding Disc brakes?? If so, add a Proportioning valve in the rear brake line.
Simple, easy fix.
Dan @ Chockostang
Matt's 95 Stang
Oct 5, 2015 07:16 AM
wraith777
Sep 28, 2015 10:49 AM
treesloth
Sep 28, 2015 07:03 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
