alignment specs
Old Jun 12, 2010 | 12:35 AM
66fstbk88's Avatar
66fstbk88
Default alignment specs
anyone have alignment specs? toe/camber and all that good stuff.
Old Jun 12, 2010 | 01:38 AM
nba1341's Avatar
nba1341
yea man I'm assuming you have a 66 fastback and were born in the year 1988.
So here they are:
Please align to these specs “1960-1966 Mustang and Falcon Performance Alignment with or without UCA drop”.
These specifications are in order of importance.
1. NO more than .25 degrees difference between driver’s side and passenger’s side.
2. +2.0 to +3.5 degrees caster.
NOTE: for cars with Adjustable strut rods. Please attain as much caster as possible using the shims (at least 1.5 to 2.0 degrees), and then use the adjustable strut rods to increase the caster and make the sides the same. Also, please note that the caster difference between the driver’s side and passenger’s side needs to have no more .25 degrees difference prior to the adjustment of the strut rods.
3. -.5 to 0 degrees camber. No positive camber, please. There is no problem having a slight variation from driver’s side to passenger’s side to account for the crown in the road.
4. 1/16" to 1/8” toe in
If you run into any problems attaining these specs, please call me (your phone number here).
Source: http://home.bresnan.net/~dazed/drop
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
