Vibration, help please ?
Old Jun 16, 2010 | 10:15 AM
livharder's Avatar
livharder
Originally Posted by KMatch
OK, it's a high frequency, intermittent (cycling) resonance to be a touch technical. Hmmm... One thing jumping out at me is something making contact that normally shouldn't, ie, exhaust on the frame, rear trans mount grounded out, engine mount collapsed. I can't rule out pinion bearings and such, but it's rare that anything from the driveshaft back will come and go at 4-5 seconds. Check mounts and exhaust and get back to us. Let's don't play that "Looks OK" business, we need to put some pressure on the mounts and really check them. Really, you just described the classic collapsed trans mount.
exhaust are ok, checked and everything clears the body, trans mount rubber seams alright cause it has still the 1 inch or so of rubber thickness between the mount and the trans. but i guess i should take it off and inspect it also.
Old Jun 16, 2010 | 12:14 PM
KMatch's Avatar
KMatch
No need to take it off. Put a prybar between the trans and crossmember. If you can lift the trans enough to "drop it" with a slight clunk, it's bad. If it just "mushes" back into place after only allowing you to lift it 1/4 to 1/2 inch, it's good. You can do similar with engine mounts, but it's much easier to check them with a helper watching the engine for movement while torquing the engine in forward and reverse gears. If you can load the engine up while holding the brakes and only get the aircleaner nut (point of reference) to move an inch or less, the mounts are likely good.
Old Jun 17, 2010 | 07:20 AM
livharder's Avatar
livharder
bumpty bump
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
