Heater Problems
Old Jun 16, 2010 | 06:05 PM
wonso79's Avatar
wonso79
Default Heater Problems
Hi,
I recently replace my heating system because the old one wasn't working. I can't get it to turn on when I turn it on. I replaced fuses, heater box and all parts. The only things I haven't replaced is the switch on the heater control ***** and wiring. All the wiring seems to be in good shape. Is there anyway to test the wiring before replace it all or any other suggestions?
Old Jun 16, 2010 | 08:44 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Here's a link to the wiring diagrams listed in the FAQ section.
WIRING
If you have basic troubleshooting skill and a multimeter you should be able to find your problem. If not... I see three choices.
You learn as you go by asking a boatload of questions, you find a friend with mad skills, or you pay someone to fix it.
I just thought of a fourth possible solution, when it's cold dress warm.
Good luck.
Old Jun 18, 2010 | 04:47 AM
tx65coupe's Avatar
tx65coupe
I would use a multimeter or a test light and see if you are getting power to the blower motor under the hood and to the blower resistor on the front of the heater box.
Old Jun 19, 2010 | 01:44 PM
wonso79's Avatar
wonso79
Thanks so much for the help!
Old Jun 20, 2010 | 09:32 AM
djsprinklesnjo's Avatar
djsprinklesnjo
let us know how you make out with it
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
