Too much shifter play
Old Jun 21, 2010 | 02:09 PM
cdeck714's Avatar
cdeck714
Default Too much shifter play
So I finally got new tires on the mustang and have been able to drive it a few days. The shifter has way too much play in it. It's a t5 5 speed. is there an adjustment or replacable bushings in it. Haven't had time to pull the shifter boot yet.
Old Jun 21, 2010 | 02:24 PM
kalli's Avatar
kalli
pull the boot. the shifter stick is mounted with two bolts to shifter. tighten them. best use locktite. mine loosened occasionally without. probably from vibration
Old Jun 22, 2010 | 10:47 PM
Randys66gt's Avatar
Randys66gt
If it's a stock shifter, there are no adjustments. Save up money for a good one! I put a B&M Ripper shifter in it and super tight!
Old Jun 23, 2010 | 07:23 AM
cdeck714's Avatar
cdeck714
Thanks guys. It feels like there is something loose. With everything else that was changed on this car by the PO i would be surprised if it was a stock shifter. But if everything is tight, I'll look into an aftermarket shifter.
kalli's Avatar
kalli
na same with the stock shifter. I bet the stick is loose (the metal rod that you're holding onto not bolted tight to the actual shifter). Common problem
Old Jun 23, 2010 | 08:19 AM
Starfury's Avatar
Starfury
There's also a small bushing at the ball/socket connection at the very bottom of the shift lever. If this bushing is destroyed, it'll cause a lot of slop.
I agree, get yourself a good aftermarket shifter. The stock shifter is rubbery and vague at best. Spend the money on something like a Pro 5.0 or Steeda Tri-Ax. I've used both and actually have a Tri-Ax in my fox body. The Hurst unit isn't that great, and I'm not a fan of the B&M (sorry Randy).
Old Jun 23, 2010 | 10:07 AM
2+2GT's Avatar
2+2GT
One disadvantage with aftermarket shifters is unless the shifter lines up squarely with the hole, you'll have to chop some floor. Not so much with the stock shifter. I had a similar problem with the similar shifter on my M5R2 trans shifter, and a couple of bucks for a new ball socket ring and it tightened up like new.
Old Jun 23, 2010 | 10:35 AM
Randys66gt's Avatar
Randys66gt
The advantages I had working at B&M was getting the modified ones....... I know, mine is better than what was sold but the Hurst and B&M (same company now) have been so mass produced, I think Tad is right.
Old Jun 24, 2010 | 08:26 AM
Starfury's Avatar
Starfury
Odd. My Tri-Ax puts the shift lever in the same spot as the stock shifter.
Old Jun 24, 2010 | 01:29 PM
2+2GT's Avatar
2+2GT
That's been my experience, too.
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
