Tailpipe to floor clearance - 65 Convertible
I am installing 2.5" pipes on my 65 Convertible and I am wondering what the clearance is supposed to be between the pipes and the floor as the pipes go over the rear axles.
I purchased Flowmaster prebent pipes for a 67 Mustang GT as they were the closest to my 65 with a GT sytle valance in a 2.5" diameter.
Does anyone have the measurement, have pictures, or have done this in the past.
Thanks!!
Thanks!!
A. Fabricate a spacer to lower the plate.
B. Create a cross brace that bolts to either the subframes or subframe connectors.
Back to the tailpipes; you feel that the pipes beiwng within a 1/2" or so of the the floor is okay? I am concerned with rattles.
I have the Flowmaster prebent tail pipes and I can tell you that they don't fit worth crap. I had to have my muffler guy modify them to fit straight. Sometime in the future, I am going to redo them I think.
I would advise just having a good exhaust shop make the tail pipes you need. Just make sure they do not have a bender that leaves the ripple effect on the pipes.
Ideally the exhaust should be at least an inch from the bottom of the car, but if its a little closer I don't think you'll have any issues.
You are right in that they will not fit completely above the plate, especially if you use an H-Pipe. Currently, they are about .5" below the plate. I have Global West subframe connectors that should help. But I am thinking about whether I want to to:
Back to the tailpipes; you feel that the pipes being within a 1/2" or so of the the floor is okay? I am concerned with rattles.
I have another car where the exhaust passes through the frame in six places. Exhaust rattles were practically standard equipment, with clearances less than 1/4". However, with careful adjusting I currently have no rattles.
I feel the subframe connectors will strengthen the chassis, but mostly in the front and back. The bars are big enough to not twist much so they should add some side-to-side support but I am thinking that adding a brace is in order.
If anyone has done this already - on a convertible - I would love some advice.
Back to the exhaust: You must have worked very hard to get 1/4" clearances to not rattle. You must be very patient.
Thoughts?
He cut them so he could twist them and he had to slightly modify the bend in them.
My exhaust guy bent and built the front part to the mufflers (x-pipe, pipes to 4.6 manifolds) but bought pre-bent 2 1/2" tail pipes. I don't know where he got them but they fit pretty well on my 65. He did have to tweak them a little to go around the Explorer rear. I guess he probably got them from a local wholesaler.
