Rear indicator not working
Old Jun 24, 2010 | 11:20 AM
mustang6501's Avatar
mustang6501
Question Rear indicator not working
On my '65 conv. the right rear turn indicator no longer flashes. All other lamps work properly. I have replaced the flasher (no change), the lamp (no change) and checked the wiring for current (there is none). I pulled the steering wheel and checked the contacts and the connector below the column and all show power. Where should I now start looking? Thanks
Old Jun 24, 2010 | 03:05 PM
jlg2002's Avatar
jlg2002
If the flasher isn't getting enough current flow to flash the rear lamp but it lights(not sure it does based on your lead-in) so you must have a high level ground or the TSS is dropping all your current. Clean the bulb base socket and housing ground to the body. measure the resistance level from the socket to ground with an Ohmmeter, it should be 5 Ohms or less. Check the pigtail leads with a test light for flashing.
Old Jun 28, 2010 | 09:08 AM
mustang6501
Thanks. I will do that.
Old Jun 28, 2010 | 01:43 PM
kalli's Avatar
kalli
can you quickly check if brake lights work?
drfister
May 3, 2018 10:38 PM
movielover40
Aug 27, 2015 10:13 PM
Tyoung68
Aug 25, 2015 04:31 AM
Mobiusone stang
Aug 24, 2015 04:08 PM
Fast-Hands
Aug 19, 2015 06:54 AM
