sub frame connectors
Old Jul 5, 2010 | 03:21 PM
runningriot's Avatar
runningriot
Default sub frame connectors
What is a good sub frame connector kit in the $200 range? I'm in the process of converting my 8" rear to a 9" with a posi unit, 3.50 gears, under ride traction bars and I think it would probably be a good idea to add some strength to the sub frame.
thanks!
Old Jul 5, 2010 | 03:31 PM
LynnBob Mustang's Avatar
LynnBob Mustang
I just put these on our '65 coupe today during the restoration process.
http://www.cjponyparts.com/product.asp?pn=SFC1
I bolted them on for now, but when I get better at welding, I'll weld them in.
Lynn
Old Jul 5, 2010 | 04:25 PM
2+2GT's Avatar
2+2GT
Good plan. Bolted-on frame connectors are essentially just decorations.
Old Jul 5, 2010 | 04:56 PM
runningriot
Lynn
I was actually looking at those, whats your impression on the quality?
Old Jul 5, 2010 | 05:18 PM
LynnBob Mustang
I thought they were good. They felt sturdy, and the hardware was good.
Lynn
Old Jul 5, 2010 | 05:24 PM
LynnBob Mustang
That's what I figured, the car is still a empty shell right now so it gives me better jacking and jack stand points. I went to jack the car up to reposition the passenger front stand and the whole side lifted up were as before only one corner would lift. It will also give me better stability when I do the drivers side rocker panel.
Lynn
Old Jul 5, 2010 | 07:23 PM
Aussie66Fastback's Avatar
Aussie66Fastback
I just installed these...
http://www.jegs.com/i/Global-West/45...oductId=760587
from the limited driving i have done since, they have completely changed the feel of the car. by taking the floor pan flex out they also show up any other issues you may have in the suspension too so either have everything in order or be prepared to make it right
Old Jul 5, 2010 | 07:46 PM
ozarks06's Avatar
ozarks06
I used TinMan. If you can weld them in, they are a good buy (about $125 I think) but are probably overkill for most cars - 11 ga steel and weigh about 40 lbs. Definitely stiffens the car.
Old Jul 5, 2010 | 08:10 PM
BuckeyeDemon's Avatar
BuckeyeDemon
these cost about $50 in materials/consumables.
11 awg steel.
Old Jul 5, 2010 | 10:50 PM
tx65coupe's Avatar
tx65coupe
Lynn
I have these same ones on mine. They fit great. I bolted them in and then had my exhaust guy weld them. I would definitely buy them again.
