9" rear end problems
Old Jul 5, 2010 | 09:59 PM
H Dean's Avatar
H Dean
Default 9" rear end problems
just put in the new 9"-finally.
works great- it has traction loc and came from a ford p/u truck.
problem is that i feel a shift when letting off the throttle. it doesnt feel like torque and does not do this when the clutch is depressed. it almost feels like the insides of the center section are shifting. not violent, but enough to make you wonder what it would do in the wet--
thanks for any suggestions.
btw- wheels and lugs are tight, all underneath is bolted in tight.
Old Jul 5, 2010 | 10:45 PM
tx65coupe's Avatar
tx65coupe
Could you be a little more specific on what is happening? Do you hear any noise or clunking when the occurs? I'm thinking that maybe the leaf spring pins are smaller than the holes in the springs perches, so the rear end walks a little. Could that be whats going on?
Old Jul 5, 2010 | 11:30 PM
racer_dave's Avatar
racer_dave
If it feels like a 'clunk' when you let off the gas, then its too much backlash. It may not be as noticeable when you push in the clutch because the engine compression isn't making resistance like it does when you just let off the gas.
Check the backlash in 3 places around the ring gear and reset as needed.
Also, for good measure, check the rear U-joint. Sometimes that can be worn and give you a 'clunk' feel, but its not usually as pronounced as the backlash issue.
Old Jul 9, 2010 | 09:10 AM
tcrote5516's Avatar
tcrote5516
Tighten up the u-bolts that mount the rear end to the leaf springs. These really need to be tight or it will create the exact problem your having.
Old Jul 10, 2010 | 04:19 AM
tx65coupe's Avatar
tx65coupe
I was thinking the same thing.
Old Jul 10, 2010 | 11:55 AM
67mustang302's Avatar
67mustang302
Also check u joints.
Tyoung68
Aug 25, 2015 04:31 AM
inyadreems
Aug 21, 2015 09:10 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
