351c engine
Old Jul 12, 2010 | 02:20 AM
mustang_garage's Avatar
mustang_garage
Default 351c engine
hi everyone, so ive been doing alot of research on this site and throughout the internet and havent found the response i was looking for so i thought id ask the question myself and see what i get..
My problem is(if this makes sence to anyone) i have no problem rebuilding an engine, if you give me the parts i'll make it work.. i have a problem with the numbers game, ie.. with 9.0-1 compression which cam would work best with that. and if i go with "x" cam which manifold would supplement the cam the best.
I have a 72 cleveland which im wanting to get between 400-425 hp out of it. it not going to be a track or strip car but i want speed and power for whenever or whereever it is i decide to drive it whether it be 200 mi to the coast or to work and back(30 mi round trip). It has the 2V heads and all the info i gathered indicated a 9.0-1 comp ratio. from what i have found, the best way to wake a cleveland is a new cam. and comp cam 270H being the most recomended for (4V) heads. mine is a 2V im wondering if that will work best for my 2v as well... and if there are any other ideas out there to make 400-425+ hp...
thanks for your time
Old Jul 13, 2010 | 01:39 AM
mustang_garage
bump....
Old Jul 13, 2010 | 04:12 AM
67mustang302's Avatar
67mustang302
Hydraulic roller cam is best, get a custom ground one and it'll easily make that power. With modified stock 2V heads and a custom hyd roller it could easily make 450-500hp at the crank on pump fuel.
Old Jul 15, 2010 | 01:36 AM
mustang_garage
thx 67mustang for the tip...i was pritty heavily leaning toward a hyd roller set up..
are there any other ppl out there who have built a cleve, know somebody that build a cleve, or just plan out has some advice on a cam set or other mods??
thanks again 67mustang
Old Jul 15, 2010 | 03:28 AM
Tomahawk715's Avatar
Tomahawk715
http://www.351c.info/forum3/index.ph...5c0bab511fb93e
Might want to poke around that site--or join up and ask specifics over there.
Old Jul 15, 2010 | 06:44 AM
kalli's Avatar
kalli
don't know much about the clevelands, wouldn't it be a good idea to slap 4v heads and intake on them or can you achive the same with working 2V heads? was wondering that noone mentioned that
Old Jul 15, 2010 | 08:56 AM
urban_cowboy's Avatar
urban_cowboy
Kalli, the 4V heads had such huge intake runners that they can actually hurt peak performance on all but the most radical motors because the velocity of the incoming air is compromised. In many cases 2V heads are more desirable.
Mustang_Garage, welcome and have fun building your engine. If you want some ideas on radical Clevelands, look at the magazine Engine Masters. The Engine Builders Challenge has been won by Cleveland based motors. CHI makes some great heads and intakes.
Old Jul 16, 2010 | 01:24 AM
67mustang302
The more modern versions of the Cleve heads use smaller ports are flow dramatically more. Probably the extreme most example of a modern Cleve heads is the NASCAR approved Brodix-Neal series heads, or something similar.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
