351w GUYS.
Old Jul 21, 2010 | 07:24 PM
eatmyjeep's Avatar
eatmyjeep
Default 351w GUYS.
what kind of intake are you running?
Im about to put in a 94 351w in my 1970 ( i found out its a boat motor block) with tho's gt heads. I just bought a performer intake. The carb I have is a holly 650 if that helps. but the problem is i just dont see how its all going to fit under the hood. bc the 302 i just pulled out left a dent in the hood where the wing nut was.
Is for some reason this "industrial" block taller?
Old Jul 21, 2010 | 07:30 PM
Deviousfred's Avatar
Deviousfred
351s will be a little bit taller than 302s because of the taller deck. They have a slightly taller deck and therefore your intake will end up a little bit higher.
Old Jul 21, 2010 | 07:40 PM
69mach1377's Avatar
69mach1377
A drop base air filter will free up some room...
Old Jul 21, 2010 | 08:20 PM
BuckeyeDemon's Avatar
BuckeyeDemon
victor jr. topped with a shaker.
Old Jul 21, 2010 | 10:29 PM
eatmyjeep's Avatar
eatmyjeep
Thanks for the input but. Theres got to be a way to do this without cuting the hood....
Old Jul 21, 2010 | 10:37 PM
Deviousfred
dropped motor mounts, and dropped base air cleaner as mentioned is a good start.
http://www.cjponyparts.com/ron-morri...970/p/MM6110L/
http://www.jegs.com/i/JEGS/555/50037/10002/-1
Old Jul 22, 2010 | 12:17 AM
shelbymustangdan's Avatar
shelbymustangdan
I'm running a 351W with a Edelbrock Performer RPM intake in a 67. The previous owner had a Torker II intake which seemed to be a bit taller.
I recently when through the exercise of changing out my air cleaner assembly, as I felt the small Ford Racing 1.5" tall assembly "may" have been restricting air intake. Although I STILL love the look of it!! After fitting a drop base K&N Extreme assembly, I sent it back and ended up buying a similar style assembly from AMSOIL.
http://www.amsoil.com/storefront/eaar.aspx
Part#EAAR2102
It fits perfectly, matches my blue spark plug wires, and leaves 3/4 to 1" hood clearance.
Old Jul 22, 2010 | 01:59 AM
BuckeyeDemon
you 100% shouldn't have to cut out the hood or use drop mounts when using a performer intake.
i was able to fit a victor even with the added required clearance of a shaker.
Old Jul 22, 2010 | 03:57 AM
kalli's Avatar
kalli
JMD has a 408 (351W) with tall intake and didn't have to modify the hood as far as I know in a 65. same with dodgestang. 351W shouldn't be much of a problem in a 70s stang
Old Jul 22, 2010 | 11:52 AM
Waffles's Avatar
Waffles
From: Detroit; where the weak are killed and eaten.
Victor Jr topped with a shaker.
