help with my distrubitor
Old Jul 25, 2010 | 08:29 PM
mazer187's Avatar
mazer187
Default help with my distrubitor
my dissy got pulled out n not knowing one of my buddys cranked the car now timing compleatly off. need sum help getting the right timing on to get it to start..i have a 68 302 block with 1990 5.0 heads...can any one help
Old Jul 25, 2010 | 09:30 PM
2005Redfire6's Avatar
2005Redfire6
You will get better answers in your car's designated section.
Old Jul 25, 2010 | 09:38 PM
Soldier GT's Avatar
Soldier GT
1st off, welcome to the forum. Second, wrong section..
Old Jul 27, 2010 | 08:40 AM
gjz30075's Avatar
gjz30075
You need to find Top Dead Center, aka, tdc. Manually turn the engine over until #1 cylinder is coming up on compression stroke. You can tell this when the spark plug is removed and your finger is covering the hole. Now start looking for the tdc mark on the balancer, the location where you'd point your timing light.
In your distributor, move the rotor to point to #1 wire. Be careful as you put the distributor in, as it will turn and you will no longer be pointing to #1. Just work with the turning thing. Once in, you'll be close enough to fire it up, then adjust your timing from there with the light.
slick66stang
Nov 5, 2012 06:14 PM
FunWheelDrive
Dec 10, 2009 11:33 AM
FunWheelDrive
Dec 9, 2009 12:44 AM
EPDP99
Aug 5, 2009 12:38 AM
jrstall
Nov 10, 2007 11:15 AM
