Need some headliner tips
Old Jul 27, 2010 | 02:53 PM
tjmat's Avatar
tjmat
Default Need some headliner tips
I'm having a little trouble getting my headliner in. I have all the stuff to put it in but does anyone have any tips as to getting it in? all help is appreciated.
Old Jul 27, 2010 | 03:13 PM
rst08tierney's Avatar
rst08tierney
tip #1.......beer, lots of it.
tip #2...... use the search, I know someone on here did a write up last year on the headliner with LOTS of pictures. What helped me was about 30 small clamps from harbor freight. They cost me about 30 cents each. Its a very hard job, to do it right, you must pull your front and rear window out to get the headliner flush under the gaskets.
Old Jul 28, 2010 | 01:21 AM
tjmat's Avatar
tjmat
ya i already pulled the glass out because i knew that's what I was going to have to do if i was going to install the new headliner properly, and thanks for the help. I really appreciate it.
Old Jul 28, 2010 | 10:48 AM
MetalEd's Avatar
MetalEd
I did mine myself and had read all the horror stories of people trying it for the first time. I did not have any of the problems other have listed and it still looks tight and wrinkle free. (it was my first time attempting it).
A couple thing I credit for not having headaches putting it in. First, I took about a week to do it. For example, I glued up the top of the rear window, clamped it all along the top and waited till the next day when the glue was good and dry before going on to the next section. I did this because I had a problem with it pulling the glue up if I pulled to hard in a different area.
The next tip, the clamps.. I had bunching between clamps or it was not holding between clamps. Not enough clamps to hold every inch to prevent this... Well if you are replacing the windlace at the same time, you have as many CUSTOM clamps as you need! Use some tin snips and cut pieces between 1-6 inches long. Squeeze the old windlace closed before re-installing it over the edges of the headliner/car edges. It will clamp and hold ever inch of the headliner in place during your install. Just make sure the glue is dry before removing it and installing the new windlace (except windows) This was the most helpful part of the install, held tight in and made the turns better than any type of clamp would have. Can't believe no one ever tried this one or posted it before. The windlace also allows you to install it completely without glue to check your alignment and see if you are going to have any problems before you glue it.
Last hint, don't be afraid to pull up an area that has been glued, just be sure to apply new glue to both surfaces before re-attaching it.
Hope you find some of these useful. Don't rush it and be sure to have some help at least some of the install and you should have no problems.
Take care
Old Aug 8, 2010 | 03:27 PM
AceBigalow's Avatar
AceBigalow
Default Headliner question
Hey everyone, didn't want to start a new thread, so just found one I could add to.
I have found someone with some GT's and parts and he has some headliners for hatchback GT's. The only thing is, he says he doesn't have one for a sunroof and that's what I need and I would have to cut a hole in it..
Is this feasible? I didn't know if it would be the same or do they do something different to the edges so it won't come apart when you buy one specifically for that... I figured that what I could do is just leave plenty of fabric left over to tuck behind that way it wouldn't come out.
I can get a headliner from him for $40, so if it will work I definitely want to do it..... A lot of people I know buy all new parts and I am not afraid to buy used but good parts because that frees up more $$$ for other things.
Old Aug 10, 2010 | 05:54 PM
groho's Avatar
groho
If someone created a molded headliner for a classic mustang, they'd be rich!!
FivePointToTheOh
Mar 9, 2020 10:26 PM
Roxon68
Mar 17, 2016 08:13 PM
Gene K
Oct 21, 2015 11:37 PM
Sep 10, 2015 08:39 PM
