No Longer Have Ignition Key
Old Aug 10, 2005 | 07:19 PM
MTE50's Avatar
MTE50
Default No Longer Have Ignition Key
Set it down in the wrong place :\ but thats another story.
Is there a way to remove my ignition without the key? Could I even just tear it out and get a new ignition?
Its a 65 mustang.
Old Aug 10, 2005 | 11:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: No Longer Have Ignition Key
To remove the ignition lock all you need to do is unfold a paper clip and insert it into the small hole in the face of the ignition switch. Rotate the switch to pull it out. Get a new switch from a vendor with the new set of keys. Now, wasn't that easy?
Old Aug 10, 2005 | 11:40 PM
ivanr77's Avatar
ivanr77
Makes me very very very happy i leave my car in a garage.
Old Aug 11, 2005 | 03:13 AM
Scott H.'s Avatar
Scott H.
I think you need the original key in the tumbler to turn the tumbler with the paper clip in place, in order to remove it.
With out the original key you need a set of locksmith tools, or a hard wax blank.
They idea behind the hard wax blank is that you insert it and turn it against the tumbler pins. This leaves an impression in the hard wax. File out the impressions and use it as a master.
Probably run about $50.00 if you hot wire the car and take it to local locksmith.
If you try to rip it out, you'll ruin the dash, which is keyed to keep the whole thing from turning.
If you hot wire the car, buy an external ballist resistor and put it in the wire you run to the coil, so that you don't end up burning up your coil before you get to the locksmith. They will make house calls but it's usually a lot more expensive.
Call around to a few places to get a price. A good locksmith will have your tumbler out faster than you can say..."I'm locking the garage from now on!!!"
Good luck,
Old Aug 11, 2005 | 05:28 AM
68COOP's Avatar
68COOP
I agree, I think you even have to turn the key over to the ACC position, then do the paper clip trick.
Old Aug 11, 2005 | 02:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that's true. You probably need to have a locksmith make you another key, then there would be no need to get a new cylinder. Here is a step-by-step article on how to remove it if you need to. http://mustangmonthly.com/howto/173_...es/index1.html
Old Aug 12, 2005 | 07:52 AM
HeavyMetal's Avatar
HeavyMetal
I was in your position not too long ago and was able to pull through it fine. You will need a new ignition lock, which does not cost a whole lot and will leave you with brand new keys! You can salvage the switch and the bezel that holds the switch on, but the lock must be destroyed. So, how I did it was I took out the drill with I think a 1/4" or 3/8" bit, see what looks best and just started drilling into where the key normally would go. This busted out all of the tumblers and with some minor persuasion popped right out. Just be sure not to drill too far into the lock because the switch is right in there behind it and be sure to disconnect your battery, because nobody likes sparks under the dash. Hope this helps ya.
Old Aug 13, 2005 | 03:50 AM
Markstang1969's Avatar
Markstang1969
ORIGINAL: HeavyMetal
Very Caveman-like! I like it!
lincolnshibuya
Dec 8, 2015 04:37 PM
bradleyb
Nov 27, 2015 07:50 PM
Thunderball
15
Nov 22, 2015 11:49 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
logan409
Sep 26, 2015 07:43 PM
