Could my Flywheel be loose??
Old Aug 27, 2010 | 02:54 AM
drewsky's Avatar
drewsky
Default Could my Flywheel be loose??
just installed my motor a few months back and have about 3 hours of running time on it or soo.. mabe 6 or 7 miles driven around the house. I fired it up to hose it off while im bodyworking it and noticed something clunking around in the bay. It really seemed like it was coming from the back so i got under and im about 90% sure its between the motor and tranny. If i rev it a little the noise seems to go away a little (its most noticeable at idle). So im thinking that its the torque converter or flywheel that i perhaps did not torque down properly.... has anyone dealt with this issue before?
My setup is a 67 coupe with 351w and c4 auto with a (1900 stall speed if i remember correctly.)
Old Aug 27, 2010 | 06:05 AM
2+2GT's Avatar
2+2GT
Did you torque it or not?
Old Aug 27, 2010 | 12:36 PM
drewsky's Avatar
drewsky
i dont believe i torqued the tq converter. the flywheel im pretty sure i did. Its been a while so i can remember exactly. Im leaning more towards the converter wobling around
Old Aug 27, 2010 | 02:07 PM
2+2GT's Avatar
2+2GT
Torquing the nuts on the converter is easy, just remove the inspection plate and have at it.
Old Aug 27, 2010 | 03:04 PM
drewsky's Avatar
drewsky
thats exactly whats gonna have to happen. I really hope this is the problem! the noise is scary sounding for sure. you think tighten the 4 bolts (north south east west) pattern should do it. really really hope this is the noise!
Old Aug 27, 2010 | 07:24 PM
2+2GT's Avatar
2+2GT
Don't bother with that, it's a flexible plate, just torque them 1-2-3-4.
Old Aug 28, 2010 | 01:17 AM
drewsky's Avatar
drewsky
alright sounds good. thx for your help thusfar. I will get under the car and check it out tomm and post back asap
Old Aug 28, 2010 | 10:16 AM
2+2GT's Avatar
2+2GT
While you're there, look for cracks in the plate.
Old Aug 28, 2010 | 01:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
sure its not the starter loose?
Old Aug 28, 2010 | 03:49 PM
drewsky's Avatar
drewsky
the starter sounds fine when its turning over... im gonna check it out in a bit, post back soon
