Headlight Issues, Please Help
Old Sep 5, 2010 | 11:53 AM
Mach1BBFun's Avatar
Mach1BBFun
Default Headlight Issues, Please Help
On my 73 mustang I noticed a short delay when I pulled the switch out for my headlights when I left my house the other day, but didn't think anything of it until when I tried to leave the place I was at I got no response from the switch.
So this is where im at, I figured it was the switch that went bad so I bought a new one, only like 15$ and nothing. All other lights work fine it is just the ones that run of the light switch. (front headlights, Parking Lights, and Dash Lights). I spent 5hrs yesterday messing with it and nothing worked.
Could anyone help me out with more suggestions?
Old Sep 7, 2010 | 04:23 PM
Mach1BBFun's Avatar
Mach1BBFun
there is power running to the harness, via yellow wire which is correct. I can not find the issue. I believe that the ground for the headlights is also on the radiator supports and the grounds are fine, I even sanded them.. PLEASE HELP ME!
Old Sep 8, 2010 | 04:48 PM
photocliff's Avatar
photocliff
Have you tried to do a search for related threads. There has been many posts on this same problem.
Old Sep 8, 2010 | 08:48 PM
JMD's Avatar
JMD
Last problem like this on the forum ended up being the DIMMER SWITCH, I missed the call on that one, kind of forgot about them.... not this time though..
Old Sep 9, 2010 | 07:45 PM
Mach1BBFun's Avatar
Mach1BBFun
Yes I have tried related threads, I have replaced the dimmer switch and the headlight switch. I don't know where to start my troubleshoot, I have checked all I can think of.
One thing very odd today was that when I was testing the power at the headlight harness, while I was plugged to positive with my tester, the two sides light up (suspected ground) but the top one did not (suspected positive). This was on the passenger light, when I plugged in the driver side light the top one did light up leading me to suspect that it is grounding out some where.
The parking lights both read all 3 wires ground also.
Anybody know where I should start???? PLEASE
Old Sep 11, 2010 | 05:46 PM
BeastMachine67's Avatar
BeastMachine67
have you checked the fuses? I had a simular problem and it ended up being a 2 amp fuse
Old Sep 11, 2010 | 07:02 PM
2+2GT's Avatar
2+2GT
There is no fuse for the headlights, the switch contains an automatic circuit breaker.
Are you getting power to the headlight switch?
Old Sep 12, 2010 | 08:38 PM
Mach1BBFun's Avatar
Mach1BBFun
Yes, the Yellow wire, Hot, Does have power
Old Sep 12, 2010 | 09:12 PM
JMD's Avatar
JMD
On a 66 switch, there are TWO hot wires, one for the parking/tail lights and a second for the headlights.
Can't say that this is the same on a 73.
Old Sep 13, 2010 | 10:58 AM
Stepman's Avatar
Stepman
Have you done anything to the car lately? I would take a look at the bulkhead connection. (where the harness goes thru the firewall) Unplug it and plug it back in.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Sep 30, 2015 10:13 AM
