Newly Rebuilt 302 Having Problems
Old Oct 1, 2010 | 03:24 PM
jaedwrds's Avatar
jaedwrds
Default Found a problem
well the engine had some pretty bad vibration. I took it back uof he car and when i was doing thata piece ofmtal fell out (uh oh). well it was the weight off of my B and M flexplate. It had a poor welding job and just fell off cracking my bellhousing (how nice). What i want to know though is where to find the casting numbers on a crankshaft. It still vibrated before i did the engine rebuild and im wondering if this crank doesnt require some different weight set up. I put 28oz on both ends which is what my year requires but now im wondering if this crank isnt from something else or some other year. I saw a 2m so i know its for a 302. Any ideas on where to find the casting number? Anyone else have this problem with engine vibration? is the crankshaft bad?
Old Oct 27, 2010 | 11:57 PM
001mustang's Avatar
001mustang
Originally Posted by jaedwrds
My distributor is an MSD billet distributor and the wires are MSD 8 mm and the spark plugs are champion...they are the ones edelbrock recommends for performer rpms heads. I have heddman long tube headers so im sure the ticking noise means i need to tighten them.
Do your heads have square ports and headers have oval ports?
Old Oct 28, 2010 | 12:11 AM
001mustang's Avatar
001mustang
i had someone tell me to disconnect the distributor vacuum advance and run the rpms up to 3000 or 3500 and then time it to 34 degrees BTDC is that correct?
Total advance is the important one.
34* total is safe and good for stock engine.
I run my cammed engine at a more aggressive 38*.
More than 38* not for the shade tree.
Old Oct 28, 2010 | 04:37 AM
kalli's Avatar
kalli
ya. you disconnect the vacuum at distributor for advance and plug the hose, then slowly rev the engine and watch the ignition advance. at some stage (usually between 3000 and 4000) it will stop advancing. this maximum advance bring to about 32-34 degrees
Old Sep 27, 2011 | 07:18 PM
charles mauer's Avatar
charles mauer
Default cam specs
what are the cam specs for the cs 108r cam i got a brand new one same cam i lost the spec sheet for so before i install it i would like to know what the specs are i bought it over a yr ago got it here in the house and was getting ready to do the top end and help or if you know were i can look this up at would also help
Old Sep 27, 2011 | 08:02 PM
racer_dave's Avatar
racer_dave
make sure the distributor housing is grounded. It won't always have a good ground if you used a new gasket. I always run a dedicated ground for the housing. Could be causing part of the electrical miss.
Old Sep 27, 2011 | 08:24 PM
charles mauer
what are the cam specs for the cs108r
Old Sep 27, 2011 | 08:27 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
NECRO_REVIVAL
Galactic
Apr 29, 2019 02:56 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
Luke9222
Sep 4, 2015 06:46 AM
