Upper control arms without shims?
Old Sep 15, 2010 | 08:52 PM
chris66dad's Avatar
chris66dad
If you are going to use an adjustable strut rod for caster adjustment on a 65-66 you will also need to have the spherical bearing pivot on the LCA to replace the rubber bushing. The rubber bushing was not designed to have a forward flex by pulling the LCA arm forward to gain positive caster. If are going to box in the LCA , Opentracker sells the bearing for a DIY to install.
Old Sep 15, 2010 | 10:43 PM
Coupe's Avatar
Coupe
Good point..I have not seriously considered those rods.
But I could also see the advantage of those rods and how they "prevent" certain movement more so than using them to move the LCA during alignment.
I wonder why nobody makes a strut rod with a front pivot that still has a fixed length? It could be a cost effective improvement since most of these cars will still end up using UCA shims anyway.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
UrS4
Sep 30, 2015 10:13 AM
