Body questions
Old Dec 1, 2003 | 03:45 PM
whew41's Avatar
whew41
Default Body questions
<IMG src=uploads/whew41/31DB8_driverdoorlower.JPG border="0">This pic is my lower driver side door. there are rust holes through the door. Should I reskin or replace the door. </P>
<IMG src=uploads/whew41/377Z6_rearend.JPG border="0">This is the rear directly below the tail light panel.....<IMG src=uploads/whew41/48CZ7_rightsidereadrail.JPG border="0">This is the rail directly below the trunk on passenger side.</P>
<IMG src=uploads/whew41/DZ551_trunkflrleft.JPG border="0">This is the interior of the trunk above the rail in the pic above. You are looking at the trunk brace where it meets the floor</P>
I am restoring a 1965 Mustang Fastback and how some body questions</P>from the pics above. As you can see they need replacing. Are these items that someone with no welding experience can do or should I have a body shop do it. If a body shop what should I expect to pay ?
Old Dec 3, 2003 | 11:43 AM
bob emmerich's Avatar
bob emmerich
The door skin and rear panel can be repaired relatively easier than the rear sections. For the rear frame rail and trunk floor, I would recommend a shop do it, unless you want to get welding practice. I had my rear rail/trunk floor done using my parts for 600 bucks. Not bad. However, I now have a welding outfit and am going to try and do all my rust repair myself(how can I get experience otherwise).</P>
If you want to learn and have the cash to get the welding outfit, practice yourself on some scrap steel, then do it. If not, pay to have it done professionally. Depends on how confident you feel in your abilities.</P>
Old Dec 7, 2003 | 02:00 AM
Obsidian71's Avatar
Obsidian71
I would say, that if you have no expirience, and you care about your car, have it done professionally, I've personally done the trunk floor and rear rails in a 66 fastback and it is very time consuming and the aftermarket parts take a little "finesse" to make them fit right. If you want to do it yourself, practice on something else first. Remember too, that you have to cut out all the old crap first and you need some tools for that too, like an air chisel, and spot-weld cutters to do a clean job.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
