C4 Tranny issue
Old Oct 23, 2010 | 06:50 PM
mustangsavage1967's Avatar
mustangsavage1967
Default C4 Tranny issue
Hi
Well today we were going to put the engine back into the car yet the tranny just acted up. When putting the toruqe converter on all the way i cant spin it and before we took the engine out i had it out before (this is part of another problem for another day) and i was able to put converter on and spin it just fine to line up the holes. Well now like i said i cant turn the converter and i know its on all the way because we put it on then spun it till it went in further meaning it was in far enough. I dont know why its locked up but the only thing we did was have new seals put in it and we replaced the pan gasket and the filter by ourselves. Any ideas? Thanks!
Old Oct 24, 2010 | 02:45 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
wonder if you damaged the front pump?
Old Oct 24, 2010 | 03:33 AM
mustangsavage1967
im not sure. How would i tell
Old Oct 25, 2010 | 11:35 PM
001mustang's Avatar
001mustang
When installing torque converter three things must line up: Input shaft, stator support and pump. Rotate tc back and forth till drops all the way in. The tc hub must rest inside bell flange; verify w/ straight edge.
Old Nov 30, 2010 | 08:55 PM
slingslingbinks's Avatar
slingslingbinks
When u removed the input seal did a piece break off and fall into the pump gears. Sound's like there is something wedged into the pump. The torque converter hub is the last thing to slide into place when installing the converter. Pull your pump and see if the gear's have something wedge in it.
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
