Suspension time
Old Oct 26, 2010 | 03:13 PM
mr_velocity's Avatar
mr_velocity
Default Suspension time
Now that the paint is done its time to focus on the suspension. What the general consensus on Total Control Products UCA? I like being able to adjust without shimming the crap out of them but I don't know anyone actually using them. Already have the holes drilled for the shelby drop.
Old Oct 26, 2010 | 04:12 PM
eZ's Avatar
eZ
Unless you are going to be autoXing the car those are very pricey. I would stick with some stockers and roller spring perches, and a negative wedge kit for the shelby drop. spend that $700 bucks somewhere else.
Old Oct 26, 2010 | 10:19 PM
Starfury's Avatar
Starfury
If you really want something like that, I'd suggest taking a trip over to Shaun @ Street Or Track. His tubular arm setup is superior to TCP's in several aspects.
Otherwise, if you want something better than stock but not outrageous, look at something from OpenTracker Racing. Even the basic control arms he offers will work for most use. They come deburred and with the nuts welded to keep them from backing off. He also offers rollerized and boxed versions.
Old Oct 27, 2010 | 07:31 AM
mr_velocity
I saw in another post you recommended Shaun but I'm unable to find any information on him. How do I get in touch with him?
The Opentracker UCA with the roller is more expensive then the TCP UCA and its not adjustable. Not sure why I would want to go this route unless the TCP UCA is not good.
I guess the first real question is "Is there really an advantage to having an adjustable UCA?"
Global West also has a nice UCA, though not adjustable.
Old Oct 27, 2010 | 08:35 AM
Starfury's Avatar
Starfury
Street or Track's website
You don't absolutely need adjustable UCA's. They're good for racing/autocross to allow you to adjust your camber curve and give yourself a little bit of caster adjustment without shims, but you don't want to use them to set your alignment (which is what happens a lot with the TCP arms). Both arms need to be set to the exact same length, otherwise you end up with different camber curves on each side of the car.
The higher priced rollerized UCA's on OpenTracker's site are boxed as well, and are designed for vintage legal racing situations where you can't run tubular suspension. Yes, they're a bit overkill for most cars. But if you call John (he runs ORP), I'm sure he could make you a pair of rollerized, unboxed arms. He used to have them on the website, in fact. Or you could just get his standard arms, which start off as Moog arms but go through his deburring and tack welding process.
Old Oct 27, 2010 | 08:52 AM
mr_velocity
Cool thanks for the info. I'm not too concerned about budget but I don't want to waste money either. I'm also looking at TCPs power rack steering.
Old Oct 27, 2010 | 10:55 AM
mr_velocity
the street or track stage 4 and 5 front end kits look pretty cool. Will have to call shaun and decide which I'm going with.
When it comes to the back, should I change the springs and lower the back of the car by 1"?
Old Oct 27, 2010 | 12:49 PM
eZ's Avatar
eZ
If not too concerned with price why not go with a 3 link or 4 link system. allow you to run a much wider tire with a lil tub job. best mod I ever did on mine.
Old Oct 27, 2010 | 01:24 PM
mr_velocity
I'll definitely check out the 3 & 4 link systems, have a manufacturer in mind?
Old Oct 27, 2010 | 07:40 PM
eZ's Avatar
eZ
I used the martz system...Allowed me to move the inner wheel well all the way to the frame. more rubber!
