CSRP and Wheels?
Old Oct 27, 2010 | 06:31 PM
coolbreze_1's Avatar
coolbreze_1
Default CSRP and Wheels?
I'm installing the grenada disk brake swap (from www.CSRP.com) on a '66 mustang, to go from 4 to 5-lugs. I would like to know if any of you have used this swap and if so, what wheels have you used with it? I'm thinking about torque thrust II's (15x7, 3.75 Backspacing, with 50 or 60 series tires).
Old Oct 27, 2010 | 06:37 PM
coolbreze_1
Oops, its not csrp.com it's http://www.discbrakeswap.com/ sorry
Old Oct 27, 2010 | 06:49 PM
2+2GT's Avatar
2+2GT
If you use Granada rotors, the hubs are quite large, making it impossible to use most 64-73 stock wheels.
Old Oct 27, 2010 | 09:46 PM
JamesW's Avatar
JamesW
3.75" backspacing on a 15x7 wheel with 60s on the front of a 66 will be a problem. probably gonna get a wheel rub. Need a deeper backspacing to pull that wheel in further.
Old Oct 28, 2010 | 04:48 AM
tx65coupe's Avatar
tx65coupe
I have Granada brakes with Magnum 500 15x7 4.25 backspacing.
Old Oct 28, 2010 | 05:55 AM
kalli's Avatar
kalli
I have that swap with 15x7" 3.75BS 205/60R15 in front no problem
new wheel I'm buying is going to be same size again
but if the TTs come in 4.25" BS as well, it might be an idea to go with them (be on the safe side)
Old Oct 28, 2010 | 07:40 PM
coolbreze_1
Thanks for the info gentlemen. I just ordered some 15/7 tt2s with 4 inch bs. Couldn't find them in a 4.25
Old Oct 28, 2010 | 09:16 PM
JamesW's Avatar
JamesW
Do you have any sort of drop springs, or upper arm relocation?
Old Oct 29, 2010 | 06:58 AM
kalli's Avatar
kalli
in front just finished shelby drop (2 weeks ago), but no drop springs. bought the springs 3-4 years ago. they were sold at NPD as heavy duty V8. car had a V8 and 6cylinder springs so had to change them
Old Oct 29, 2010 | 09:16 AM
JamesW's Avatar
JamesW
Maybe that's why. I had the 620 coils with the 1" drop.
