Electronic Flasher Problem
Old Oct 31, 2010 | 06:46 AM
tx65coupe's Avatar
tx65coupe
Question Electronic Flasher Problem
I have the Scott Drake sequential tail lights on my 65. Last night an odd problem started with the variable rate electronic flasher module. When the car is running it clicks like the turn signals are on when they are off. They work though. What could be causing this? Maybe a bad ground? The weird part is that when the key is on it doesn't do it, but once the engine is running it starts clicking.
http://www.drakeautomotivegroup.com/...0.aspx?wid=141
Old Nov 1, 2010 | 06:06 PM
001mustang's Avatar
001mustang
If it's clicking then current is passing through it.
Should be no current when lights are in off.
Double check that nothing else is in the flasher circuit.
Old Nov 1, 2010 | 08:51 PM
JMD's Avatar
JMD
How does the box hook up?
Meaning, where do the wires hook to, and where is the box located in your car?
Old Nov 2, 2010 | 06:04 AM
tx65coupe's Avatar
tx65coupe
It connects to the 2 stock flasher wires and has its own ground wire. I have it mounted with zip ties near the stock location on the back of the fresh air vent.
Old Nov 2, 2010 | 09:45 AM
001mustang's Avatar
001mustang
When it is clicking I would use stethoscope to verify it's coming from flasher.
Use volt meter to verify no voltage from red and yellow wire to ground.
Old Nov 3, 2010 | 03:45 AM
tx65coupe's Avatar
tx65coupe
Thats a good idea. I'm going to check into it more in the next few days.
I did have my head right next to the fresh air vent and the sound is coming from it or behind it. The only thing there is the flasher. I'm 95% sure its what is clicking.
Old Nov 3, 2010 | 03:47 AM
tx65coupe's Avatar
tx65coupe
Maybe somethinig is making contact with one of the wires and shorting it?
Old Nov 3, 2010 | 09:58 AM
JMD's Avatar
JMD
I have been thinking about this from time to time I keep drawing a blank....
maybe there is a grounding issue?
Old Nov 4, 2010 | 04:15 AM
tx65coupe's Avatar
tx65coupe
I'm starting to think the same thing. I just don't see what the problem could be.
Its weird though, because I can not recreate the problem with just the key on. The car has to be running.
Old Nov 4, 2010 | 09:52 AM
001mustang's Avatar
001mustang
Did you check voltage from red and yellow wire to ground?
Other things can cause a similar sound when engine is running.
A leaky plug wire can cause similar sound at idle.
Does the frequency vary w/ rpm or speed?
