Hidden MP3 player????
Old Nov 2, 2010 | 02:09 AM
EZFEED's Avatar
EZFEED
Default Hidden MP3 player????
Hey guys, I want to rig some means of splicing an MP3 player into my radio wiring of my 67 vert.
I don't want to replace the original setup. Right now I have a NOS factory 8-Track and I want to be able to use that since I have a pretty decent collection of them. The radio is AM only I seem to recall and that presents a problem for an FM modulator I'd guess?
How can I plug one in? I figure I will need some sort of amplifier to boost the output?
What can I do short of cramming an AM/FM/CD/MP3 player in the glovebox? I'm sure with that I'll have to split both systems with a toggle switch to keep power from feeding back into the one not being used.
Old Nov 2, 2010 | 07:26 AM
gjz30075's Avatar
gjz30075
This might do the trick for you:
http://www.wardsclassiccarradiorepair.com/id17.html
I talked with the owner and he says the external wire is a normally open (or, maybe is normally closed) and the radio will work until an ipod unit is plugged in. Then the ipod works.
Old Nov 2, 2010 | 07:37 AM
EZFEED's Avatar
EZFEED
HOLY CRAP! :O That's exactly what I need!!!!
Before I write to them, has anyone here done this and have a DIY method?????
Old Nov 2, 2010 | 08:50 AM
CarGuyZM10's Avatar
CarGuyZM10
Not to change the subject, but how do you keep 8-tracks from falling apart. A lot of the ones I have seem to come apart at the seam of the tape, or you can hear two songs at the same time as it plays.
I wish you luck on your project. Sounds like a great one!
Old Nov 2, 2010 | 11:18 AM
mySAVIOReigns's Avatar
mySAVIOReigns
That would be really awesome if someone could figure out how to do that (DIY). It doesn't look too complex but I don't know how it would tie into the circuitry.
Old Nov 2, 2010 | 12:10 PM
MustangFTW
Guest
Posts: n/a
I know there is a way to do this if it has a cassette player, there a fake cassette that has a wire coming out so you put the cassette in and plug the wire into ipod, my friend has this one he uses it in his corolla. as for 8 track there could be something similar not sure.
not exactly DIY but its not too expensive prolly find everything for 15-20 bucks
UPDATE:
there is a 8 track cassette adapter (stick the cassette into adapter then adapter into 8 track) then get the cassette w/ipod connection and plug that into the first assembly
http://cgi.ebay.com/VINTAGE-8-TRACK-...#ht_1150wt_106
http://www.amazon.com/Macally-PodTap.../dp/B0001YXWNM
Old Nov 2, 2010 | 12:51 PM
gjz30075's Avatar
gjz30075
Exactly right, MustangFTW. I have one of those for my 8 track, however the 8 track, although recently overhauled, still sounds wavey and slow with a known good 8 track tape and the adapter barely works at all. I don't think it's that dependable as the ipod wire in the AM radio. It should work better and I will probably go that route soon.
Old Nov 2, 2010 | 01:34 PM
urban_cowboy's Avatar
urban_cowboy
Nice.
Old Nov 2, 2010 | 10:15 PM
EZFEED's Avatar
EZFEED
WHAT! Awesome!!!!
I might just pick that up just in case. My 8-track actually plays great and you can find new 8-tracks on ebay. I have several new KISS, Jefferson Airplane, Ted Nugent, and various other 8-tracks.
I still want to go the AM route gjz30075 posted. It would be way more reliable.
Old Nov 3, 2010 | 09:14 AM
MustangFTW
Guest
Posts: n/a
iwas just in my friends car and he had his ipod connectd to his cassette player the audio was amazingly clear, but if your 8 track player is iffy then i see how it can mess the sound up
