Coolant filter screen
Old Nov 9, 2010 | 11:00 PM
001mustang's Avatar
001mustang
Good info.
Could learn a lot from truckers.
They should have tons of real world maintenance data.
I could put a DIY strainer in heater core hose. When strainer plugs only thing that would happen is heater wouldn't work till strainer cleaned.
Old Nov 10, 2010 | 12:01 AM
TexasAxMan's Avatar
TexasAxMan
Originally Posted by JMD
Dirty antifreeze will plug a paint strainer right now, imo if a person wants to torch an engine, put a screen in the cooling system.
There is a reason that OEM's don't use these.
There are purpose made inline filters for cooling systems, while I don't advise their use either, they would likely be better than a homemade "screen". I want to think that a purpose made filter would spread the area of the filter to an area much greater than the cross section of the hose, which is way, way too small for a filter.
A BETTER idea would be to use a "big truck" style filter, what they do is run a spin on filter through heater size hoses, this will filter the coolant without obstructing the cooling path (big hoses).
Do you get me? it is a bypass filter, not a full flow. (these filters also have a pellet with cooling system additives to extend coolant life indefinitely, pretty smart....)
Good advice. I didn't use one of those guano filters (I know I spelled it wrong, on purpose) as I feel cooling is almost as important as oil pressure (and filter changes). This just spells disaster IMHO. The big rig thing I didn't know about, and will check into, but it's pretty easy to flush-n-fill once every year or so, hey, they even make a kit by that name .... (severe run on sentence, sorry to any English teachers ...)
Old Nov 10, 2010 | 07:39 AM
JMD's Avatar
JMD
Originally Posted by 001mustang
Good info.
Exactly!, this way you get the benefits without the risk, of course the filter will only work when there is water going through the core, but then you could always run a controlled (valve to control excessive flow) heater core bypass hose for year round filtering.
It isn't unusual to will run coolant for 500,000 miles or more in big trucks while changing the coolant filter every 30,000 miles or so.
Old Nov 10, 2010 | 10:16 AM
001mustang's Avatar
001mustang
Those spin on heavy equipment conditioning coolant filters are readily available for about 10 bucks.
Wouldn't mind having one on 66 GMC heater hose or as a temporary maintenance filter on other car's heater hoses.
A bit on the overkill side.
Old Nov 10, 2010 | 10:58 AM
1971mach1's Avatar
1971mach1
I'm far too lazy and poor to change coolant in all my rides once a year.
I have gotten several years service by using only distilled water and coolant.
I am just curious what kind of trash is lurking and looking for a core passage to plug.
Your logic is baffling.
Just get some Extended Service Prestone and it's good for more than 5 years.
You'll spend way more than the $10 cost of fluid on that filter contraption that
may or may not work, plus spend way more time to install.
BTW: The regular Prestone is good for 2+ years.
The corrosion inhibitors in coolant wears out in a certain time and a filter won't replace those, it will
just filter out more rust that the corrosion inhibitors are no longer there to prevent.
Old Nov 10, 2010 | 11:23 AM
001mustang's Avatar
001mustang
OK, so I'm a lil crazy.
I have seen particulates trapped in filter after coolant flush was performed.
I know that typical coolant flush procedure will not completely clean system.
I am not equipped to remove all tap water post flush.
I know that tap water can promote scaling more than distilled water.
I know of countless cooling systems that decline in performance over the years.
JMD educated me that heavy equipment uses conditioning coolant filters routinely.
Old Nov 10, 2010 | 07:38 PM
JamesW's Avatar
JamesW
I've had mine for probably 8 years. Never had a lick of trouble with it. I check it maybe once a year. it has a tiny bit in the mesh and I clean it and put it back.
Old Nov 10, 2010 | 08:00 PM
mr_velocity's Avatar
mr_velocity
we use these in the smaller boats
Will catch all the big stuff and will take a long time to clog up.
Old Nov 12, 2010 | 11:56 PM
az1966's Avatar
az1966
I made mine from a spagetti strainer,,,wraped it around the handle of a large screw driver and cut the excess off,,,,,stuffed into the return tube of the radiator and folded the excess over the end and then slipeed the hose of it it,,kinda a pain to flush but works for 8 bucks
Old Nov 22, 2010 | 09:06 PM
001mustang's Avatar
001mustang
Default Conditioning coolant filter
I have 3 rides scheduled for flush.
Don't want to introduce tap water due to possible scaling issues.
I bought some spin on coolant filter heads and some 30 micron conditioning filters w/ 1 oz time release DCA. Will install in heater hoses. May leave filter on truck and remove filters from Mustangs once satisfied solids are filtered out.
When DCA is expired I will introduce type 4 LCA as required per test strips.
To minimize O2 in systems I am installing coolant recovery tanks.
Thanks.
