PCV
Old Nov 12, 2010 | 02:10 PM
BeastMachine67's Avatar
BeastMachine67
Default PCV
Hey guys, I had a question that maybe some of you can help me out with. how important is the PCV valve? Do I need it? I ask this because I want to get a pair of valve covers that dont have a opening for a PCV valve.
Old Nov 12, 2010 | 05:01 PM
groho's Avatar
groho
PCV, positive crankcase ventilation, is critical, especially at higher RPMs to help release crank case pressure built up by the combustion process. Piston rings do not seal 100%. At the time of ignition, some of that expanding gases squeak by into the crank case causing pressure, referred to as blowby. If you don't use a PCV that pressure will eventually release somewhere such as a blown gasket; oil pan, intake, etc. Most valve covers have a location to drill for a PCV adapter. Here is a quick search on web. http://www.aa1car.com/library/pcv.htm , to better help you understand.
Old Nov 12, 2010 | 06:09 PM
Starfury's Avatar
Starfury
In addition to releasing pressure, PCV valves also remove corrosive exhaust gases from the crankcase. Without a PCV valve, the crankcase tends to accumulate a layer of slightly corrosive crap all over the place. Not great for engine longevity.
There is no downside to running a PCV system, until you get into severe high performance situations where there is no engine vacuum to run the PCV valve.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
