Fan Size
Old Nov 17, 2010 | 06:14 AM
UBY289's Avatar
UBY289
Question Fan Size
Any recommendation on what size of a electric fan to install on a 67 with a 289. Someone must have done this to their car.
Old Nov 17, 2010 | 08:32 AM
Starfury's Avatar
Starfury
As big as possible, which usually means >2500CFM. Taurus and Mark VII fans are common swaps because they're common, cheap, and pull a lot of air at full power.
Keep in mind, you may need to consider upgrading your alternator to meed the fan's power demands. Good electric fans will pull a lot of power, leaving little left while idling along in stop and go traffic.
Old Nov 17, 2010 | 09:07 AM
2+2GT's Avatar
2+2GT
Why ?
Old Nov 17, 2010 | 09:35 AM
rtintwo's Avatar
rtintwo
Are you having cooling issues or planning a motor swap?
Old Nov 17, 2010 | 12:18 PM
UBY289's Avatar
UBY289
Originally Posted by 2+2GT
Why ?
Just freeing up some HP.
Old Nov 17, 2010 | 01:14 PM
2+2GT's Avatar
2+2GT
A thermal clutch fan will do that for less money and a lot less work.
Ford often used them on performance engines.
Old Nov 18, 2010 | 05:39 PM
UBY289's Avatar
UBY289
Thanks .I have this set up with a new clutch fan.Think I will leave what I have.I thought I might get more some more HP by going with electric fan. Thanks
Old Nov 18, 2010 | 07:07 PM
tcrote5516's Avatar
tcrote5516
Even a clutch fan adds unsprung weight to the rotating assembly that an electric avoids. I admit being a fan of electric fans...all the cooling when you need it...NO parasitic load when you dont.
I have a 16" and it more then cuts the mustard.
I dont have A/Cto be fair, but no amount of traffic on a 110deg hwy will make it overheat and I'm running some seriously advanced timing.
Old Nov 18, 2010 | 08:36 PM
UBY289's Avatar
UBY289
Any idea on what CFM it is that you are using.
Old Nov 18, 2010 | 08:45 PM
Gun Jam's Avatar
Gun Jam
As long as your not running the stock fan you are doing pretty good. If you had the stock fan I would say go electric but if you have the clutch fan and everything is working fine I would leave well enough alone.
-Gun
