A little help..
Old Aug 18, 2005 | 05:44 PM
White Horse's Avatar
White Horse
Default A little help..
Hi,
This is my first time, so be gentle.. I'm trying to replace all the rubber around the doors on my '65 coupe. I know this is a do-it-yourself thing, but I really would like someone to handle it for me (especially the wing windows). Who would do this kind of work (body shop, glass shop?) and can anyone sugest a shop in Southern California that may be able to help me? Also, reading through some of the other posts there has been mention of a Mustang parts house "NPD" - can you advise me about this vendor, I'm unfamilliar with them. My gear selector (automatic) has worn down the "teeth" that positions the selector (and holds it) in the chosen gear. I have not seen a repacement for this item anywhere - lots of nylon bushings, but not this associated part..is this a junk yard deal? As long as we're at it, has anyone upgraded their factory air conditioning to handle R-22? I still have R-12 in the system, but it's leaking slowly (needs help about once a season). I'd like to know if the original '65 factory compressor can be used. Finally, has anoyone encountered a conversion from coupe to convertable that makes a quality transformation - and are there any professionals specializing in this kind of work in my area (as mentioned above Southern California)?
Thanks in advance for your help, happy motoring
Old Aug 20, 2005 | 04:36 PM
pootscratch89's Avatar
pootscratch89
Default RE: A little help..
White Horse,
The correct referigerant upgrade is R134a, not R22--R22 is used for fridgerators and houses. They sell a kit you can purchase from your local parts dealer to upgrade. However, you really need to take it to an A/C place to remove the old R12 and oil; they cannot mix. It sounds like you have some leaks, so taking it it for the conversions might be perfect.
Vern
Old Aug 20, 2005 | 05:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
First of all, welcome to the site. Unfortunately, there aren't many restoration places that will replace the rubber around your windows without having them restore your entire body. Most of us do that ourselves. You can get the rubber from many Mustang vendors, but one I would recommend is Mustang Unlimited. NPD is also another good supplier. So, hike up your sleeves, order the parts, and do it yourself.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
labudski
Aug 24, 2015 07:23 AM
Pain.
Aug 7, 2015 10:48 PM
Demoneyejin
21
Oct 23, 2006 07:17 PM
Mt Twigbert
Apr 15, 2006 03:17 PM
