timing question
Old Nov 22, 2010 | 06:18 PM
emttrevor's Avatar
emttrevor
Default timing question
I have a 67 mustang with a rebuilt 302 engine that is about 1990 model engine with a high end cam in it it was a comp cam the kit number was i believe a 35-302-8 i am having problems timing it. I wired it as a 302 but someone told me that when u put a high end cam you have to wire it as a 351 does anyone know if this is correct
Old Nov 22, 2010 | 07:59 PM
nba1341's Avatar
nba1341
use 302 HO firing order
Old Nov 23, 2010 | 08:54 AM
Starfury's Avatar
Starfury
Check with Comp Cams. Most roller cams use the 351W firing order.
Old Nov 23, 2010 | 09:00 AM
KMatch's Avatar
KMatch
"High end" has no meaning here. The difference is whether the cam was ground as an HO or not. HO uses the 351 order, non HO uses 302 (if it's intended for a 302). Been there, done that... And since 302 and 351 cams interchange, well, you just have to make sure of the firing order however it's labeled.
Old Nov 23, 2010 | 09:53 AM
emttrevor's Avatar
emttrevor
thanks guys 351 worked
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
