Dash Cut
Old Nov 29, 2010 | 07:32 PM
Joes65's Avatar
Joes65
Default Dash Cut
Working through a 65 coupe I recently purchased. The dash has been cut up a bit to accommodate a tape deck, specifically 2 additional holes where very crudely drilled for the tuning *****.
So basically replacing it with an oem look-a-like is out without replacing the dash or using one of those weld in patch kits. Any ideas for a temp fix? I would like to do it right at some point but it might be a while before I can go down that road.
Thanks
Joe
Old Nov 29, 2010 | 08:05 PM
noroof66's Avatar
noroof66
You should still be able to use the patch kit, but weld later. The nuts on the radio should hold it in place, or you can just use mild adhesive behind it.
Old Nov 29, 2010 | 08:35 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Going with an OEM style stereo limits your options. They're not bad units but they're dated. Because the dash is already cut it wouldn't be a sin to cut it to DIN size, then you could install a true state of the art type unit. Unless you're a concourse kind of guy... If so, well...Never mind.
Old Nov 29, 2010 | 11:01 PM
andrewmp6's Avatar
andrewmp6
Cut it for a din or radio delete plate is all you can do with out welding.
Old Nov 30, 2010 | 09:19 PM
2+2GT's Avatar
2+2GT
Really, only two holes? No big chop?
Old Nov 30, 2010 | 09:32 PM
Joes65's Avatar
Joes65
Na just 2 holes, looks like a chipping hammer was used to make them though.
lincolnshibuya
Oct 6, 2015 08:45 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
mdg
Oct 1, 2015 07:04 AM
