Exhaust
Old Dec 7, 2010 | 03:48 PM
tdg01's Avatar
tdg01
Where do you get the Motive Kit? I did a quick search and didn't find an exhaust kit. .ii
Old Dec 7, 2010 | 05:51 PM
kalli's Avatar
kalli
Google for glazier Nolan ;-) www.mustangbarn.com
Old Dec 7, 2010 | 08:31 PM
tx65coupe's Avatar
tx65coupe
I'm curious why you want to change the exhaust system?
I'd cast my vote for the Arvinode setup.
Old Dec 7, 2010 | 09:38 PM
Joes65's Avatar
Joes65
I don't really want to change it, its rusted pretty bad and looks to need replacing.
Old Dec 8, 2010 | 09:28 AM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by 2+2GT
Seriously, no welding is required with the Motive systems, unless you are going "show-correct", eliminating clamps.
I've always found welding to be more reliable, though. Less likely to leak, or let the connection come loose or develop a hinge like the U-bolt kind always seem to end up doing. Maybe the band type of clamps like on the new Mustangs are better?
Either way, I would not approach this kind of job convinced that everything is going to fit as accurately as dropping a new intake manifold on the engine, and that you'll absolutely be able to just tighten a few bolts and be done with it. Exhaust systems aren't that accurate, and clearances can change over the years.
Norm
Old Dec 8, 2010 | 12:50 PM
jp1967stang's Avatar
jp1967stang
I think you should find a good shop to do it so when its done you can see that the trumpets are straight. The kit that was used on my car we had to put a pipe in the tail pipe and bend it straight so the trumpets would line up right. And they still didnt.
Dokilar
15
Oct 16, 2015 08:13 PM
Sep 30, 2015 12:39 PM
junior04
Sep 28, 2015 10:53 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Sep 24, 2015 09:18 PM
