ring and pinion gear set....
Old Dec 6, 2010 | 10:29 PM
CyprusMustang's Avatar
CyprusMustang
Default ring and pinion gear set....
currently doing 4500 rpm at 65mph, im running a stock rear axle. If I change the gear ratios to 3.25:1, what do you guys think my rpms would be at 65 mph?
next question, im changing my c4 to c6. Was gonna change to t5 but really like auto, would this change the rpms as c6 newer tranny?
and last, im also upgrading to 351 with stroker kit maybe to 408, not sure yet, would the above gears in rear axle make that much difference on acceleration and if so, would it be noticable even when upgrading to bigger engine?
Old Dec 6, 2010 | 10:34 PM
Gun Jam's Avatar
Gun Jam
4500 at 65? What are you running a 5.11 rear end? Or really tiny rear tire height like something 16" tall (25" is stock)
none of this adds up whats going on?
Do you know your current rear end ratio?
Old Dec 6, 2010 | 10:53 PM
Gun Jam's Avatar
Gun Jam
Oh I almost forgot..
If your rear tire height is 25" AND you stay with your c4 or 1:1 final gear and your rear end gear is 3.25
Then RPM is 2800 @ 65 mph
OR
RPM is 4500 @ 103 mph
Old Dec 7, 2010 | 12:56 AM
67mustang302's Avatar
67mustang302
Holy crap. How are you doing 4,500rpm at 65? I don't even do that with 3.55's in 3rd on my TKO.
Old Dec 7, 2010 | 06:49 AM
kalli's Avatar
kalli
very same here. i'm running 4100 in 3rd on 3.5:1 at 65mph!
either you're missing a gear, your speedo is off or you have an utterly mad rear axle or tyres from a go kart
check on what you have first:
a) check speedo against novigation system. 5mph out is no problem, rather expected.
b) what rear tyre size do you have? example: 225/60R15
c) do you have a timing gun that shows rpm or any other rpm gauge so you cna verify your readings. maybe someone stuck a 6cylinder rpm gauge in there???
d) what is your current rear axle ratio. we can never assume it's stock. and even if we were sure it's stock we need door data plate to check what it was in your car.
Measure the rear axle ratio:
- car in neutral, back lifted. if you turn a tyre as if you were driving forward, what does the other tyre do? go forward as well (locked rear), or turn the opposite direction going backwards (open rear)?
if locked rear. count how many turns you need to do on wheel so that the driveshaft turns exactly once. that's your rear axle ratio
if open rear, same as above, but double the value at end (for example it takes 1.75 turns on wheel to turn the shaft once while holding the other wheel): 3.5:1 ratio
Then check if you're missing. switch through all gears in auto. you should have three gears
Kalli
baddog671
Jul 26, 2016 01:20 PM
Bokeo
Oct 10, 2015 08:28 PM
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
