Need Help: Control Valve
Old Dec 14, 2010 | 03:05 PM
guitarman376's Avatar
guitarman376
Default Need Help: Control Valve
Hey guys I can't figure out how to remove the shorter power steering hoses attached to the control valve. I am speaking about the side that goes through the little mount thingy (not the side that actually goes into the power cylinder). I see that both the pressure and return side have nuts on each side, but I can't get any type of wrench or channel-locks on them. Can anyone help me out? Thanks!
Old Dec 14, 2010 | 05:00 PM
2+2GT's Avatar
2+2GT
You need a flare nut wrench.
Old Dec 15, 2010 | 04:26 AM
kalli's Avatar
kalli
amen!
Old Dec 15, 2010 | 08:30 AM
KMatch's Avatar
KMatch
I couldn't imagine doing power steering work in my job with crowsfoot wrenches. Would these get you closer to what you need? http://www.google.com/images?hl=en&s...w=1345&bih=547
Old Dec 15, 2010 | 08:43 AM
2+2GT's Avatar
2+2GT
As long as he chose the flare-nut type:
Old Dec 15, 2010 | 03:50 PM
chockostang's Avatar
chockostang
As I'm sure you have experienced by now, the thick collared wrenches will not fit between the nut on the tubing, and the control body, Especially on the Pressure hose.
So, if you are changing the hoses, cut the tubing off the nut, then use a 6 point socket to remove the nut.
This will work on all the fixtures.
Make sure you change the seats. Leakage reoccuring after adding new hoses is a high percent factor.
Dan @ Chockostang
Old Dec 15, 2010 | 04:15 PM
kalli's Avatar
kalli
i'll make sure to check that the next time. brute force is sometimes the way to go :-)
Old Dec 16, 2010 | 08:01 AM
KMatch's Avatar
KMatch
Actually, brute force is a way of life. When that fails, read the directions.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
UrS4
Oct 3, 2015 06:23 AM
ChampInSD
Oct 2, 2015 04:55 AM
